Post by firemac on Jun 6, 2019 9:50:51 GMT
AC50 is good stuff, Paul and should do the job. Nevertheless there's nothing to stop you costing it with something further (Hammerite, Dinitrol,Waxoyl, etc). Maybe do it in the autumn before winter sets in?
Post by Paulus17 on Jun 6, 2019 11:28:37 GMT
AC50 is good stuff, Paul and should do the job. Nevertheless there's nothing to stop you costing it with something further (Hammerite, Dinitrol,Waxoyl, etc). Maybe do it in the autumn before winter sets in? Cheers Jim :TU: Looking more into using AC50 is it more suited to keeping clean metal rust free or is it ok doing what I've done on rusted areas?
Post by firemac on Jun 6, 2019 11:42:07 GMT
AC50's fine. It's often used to keep motorcycles rustfree in winter conditions. It originated in the aviation industry where it is used to keep airframes rustfree. So it will be up to your job okay.😀
Post by Hoovie on Jun 6, 2019 11:48:54 GMT
As I mentioned previously, Hammerite Krust is a good product for neutralising the rust that has already taken place. Just painting over rust is rarely succesful.
Post by Paulus17 on Jun 6, 2019 11:49:48 GMT
OK Jim I will give it a coat of Hammerite as well as David suggests :yes:
Post by Paulus17 on Jun 6, 2019 18:53:59 GMT
Well I ordered the one dust shroud today from Kingo so should be here sometime next week,then gotta find someone to fit it :yes: Will I need to coat it in summat to give it some protection before fitting it?
Post by Paulus17 on Jun 6, 2019 18:54:58 GMT
As I mentioned previously, Hammerite Krust is a good product for neutralising the rust that has already taken place. Just painting over rust is rarely succesful. Is that KURUST David?
Post by bothwellbuyer on Jun 7, 2019 18:21:20 GMT
Well I ordered the one dust shroud today from Kingo so should be here sometime next week,then gotta find someone to fit it Will I need to coat it in summat to give it some protection before fitting it? Protection for the shroud Try an umbrella, suitably cut down. As it'll be hit by stones; gravel and other crud, I don't think there is anything that would protect it.
On the fuel pipes, I found the breather pipe was thinner/rotted faster down at the bottom curve as shown by your pics. I painted mine with loads of hammerite...and left the plastic cover off on one.....one option would be to slit a plastic reinforced plastic hose and tie it round for protection. tbh, I'm surprised that Toyota didn't change this design fault years ago.
you would need to treat the rust, then paint over ideally..do it while the weather is warm as sitting on cold ground will give you piles.
Post by bigkev on Jun 7, 2019 18:35:53 GMT
Well I ordered the one dust shroud today from Kingo so should be here sometime next week,then gotta find someone to fit it Will I need to coat it in summat to give it some protection before fitting it? Since the wan that fell aff had been on for 17 years, dinnae bother coating the new wan, Paul min........it comes black powder coated and will more than likely last longer than you keep the car. Slotting the bolt holes to suit is a dawdle.
Post by three5 on Jun 7, 2019 20:02:10 GMT
This is not really relevant to Pauls motor Bothy, but I had the pipe on my 4.3 changed last November and the guy doing the job - very experienced with RAV's - said that there was much better protection on the new one than he had seen before. Mine was 11 years old when it failed so Pauls has done VERY well. I was tempted to keep the old pipe and draw up and manufacture one in stainless steel, but if this one last 11 or more years it will probably see me out never mind the car!
Post by three5 on Jun 8, 2019 7:44:15 GMT
Just to clear up a technical point: Kurust is a phosphoric acid based product that "converts" iron oxide ( - rust ) into iron phosphate which is a stable(ish) coating on the surface of treated ferrous metals KRUST is available very occassionally from Kingo. It's what he has left over when he's finished his pie!
Post by bigkev on Jun 8, 2019 8:26:23 GMT
Just to clear up a technical point: Kurust is a phosphoric acid based product that "converts" iron oxide ( - rust ) into iron phosphate which is a stable(ish) coating on the surface of treated ferrous metals KRUST is available very occassionally from Kingo. It's what he has left over when he's finished his pie! No need to have a go at my mate Kingo there, Teaman.......he has acksherly lost a lot of weight, and now he has six grand to pay for his garden, he will not be eating at all.......!!
Post by three5 on Jun 8, 2019 8:42:14 GMT
Just to clear up a technical point: Kurust is a phosphoric acid based product that "converts" iron oxide ( - rust ) into iron phosphate which is a stable(ish) coating on the surface of treated ferrous metals KRUST is available very occassionally from Kingo. It's what he has left over when he's finished his pie! No need to have a go at my mate Kingo there, Teaman.......he has acksherly lost a lot of weight, and now he has six grand to pay for his garden, he will not be eating at all.......!! I'd heard this story of the new svelt Kingo as well. Good luck to him ( and well done! ), I know how hard it is to lose weight. So is he resisting all pies these days? As he seemed to get "paid" in them a few years since, the supply of KRUST might be increasing?
Post by Paulus17 on Jun 8, 2019 10:12:24 GMT
Good ideas Bothy but what about spraying the whole area inc the pipes with expanding foam and cutting/shaping it to suit?
Post by Paulus17 on Jun 8, 2019 10:13:06 GMT
Well I ordered the one dust shroud today from Kingo so should be here sometime next week,then gotta find someone to fit it Will I need to coat it in summat to give it some protection before fitting it? Since the wan that fell aff had been on for 17 years, dinnae bother coating the new wan, Paul min........it comes black powder coated and will more than likely last longer than you keep the car. Slotting the bolt holes to suit is a dawdle. Good thinking Kev old boy :TU:
