Post by Paulus17 on Aug 23, 2022 17:55:52 GMT
Thanks for the replies folks but i have a little more info now. Mrs P thought the chrome circle around the socket was part of the plug and she said she did try pulling that out when the plug had broke, so depending on how hard she tried getting that out could she have caused any damage to the socket. Also that bit of plastic David noticed seems to have gone now. Re the plugs i am using, the one that's springing out now is what i use when we go out and i use Google maps with the phone and use to charge the phone so that has always worked. The other is a twin socket adaptor that plugs into the ciggy lighter and that fits perfectly still but there is no power going to it as there is a cluster of lights on the front which aren't lighting up?? A new piccy of the inside showing the plastic bit gone and the outer chrome circle Mrs P tried pulling out. ![](https://i.ibb.co/RQYfV4K/ravciggy.jpg)
Post by davrav on Aug 23, 2022 18:15:36 GMT
Ah ha, so the base could well be damaged/drawn up/disconnected then.........
Post by Paulus17 on Aug 24, 2022 7:26:48 GMT
Ah ha, so the base could well be damaged/drawn up/disconnected then......... I'm not sure David as it seems to be in there tight, she said she just tried pulling it out using here fingers?? And the other thing now i've found out is that the Nextbase dashcam isn't working :no:
Post by jasehutch on Aug 24, 2022 9:11:26 GMT
Ah ha, so the base could well be damaged/drawn up/disconnected then......... I'm not sure David as it seems to be in there tight, she said she just tried pulling it out using here fingers?? And the other thing now i've found out is that the Nextbase dashcam isn't working Where's that wired into Paul ?
Post by firemac on Aug 24, 2022 9:50:12 GMT
Ah ha, so the base could well be damaged/drawn up/disconnected then......... I'm not sure David as it seems to be in there tight, she said she just tried pulling it out using here fingers?? And the other thing now i've found out is that the Nextbase dashcam isn't working Try plugging it into your PC. 😊
Post by Paulus17 on Aug 24, 2022 9:59:46 GMT
I'm not sure David as it seems to be in there tight, she said she just tried pulling it out using here fingers?? And the other thing now i've found out is that the Nextbase dashcam isn't working Where's that wired into Paul ? It was the cigarette lighter Jase but i tried it on the lappy and but nothing :no:
Post by Paulus17 on Aug 24, 2022 10:00:34 GMT
I'm not sure David as it seems to be in there tight, she said she just tried pulling it out using here fingers?? And the other thing now i've found out is that the Nextbase dashcam isn't working Try plugging it into your PC. 😊 That's how i tried it Jim :yes:
Post by firemac on Aug 24, 2022 10:31:46 GMT
Try plugging it into your PC. 😊 That's how i tried it Jim :yes: when you tried it on the PC, Paul, did you use a different usb cable to the one that powers it in the car? I’m wondering if any of the cable connections were damaged when the plug was pulled out of the socket.
Post by Paulus17 on Aug 24, 2022 10:48:59 GMT
That's how i tried it Jim when you tried it on the PC, Paul, did you use a different usb cable to the one that powers it in the car? I’m wondering if any of the cable connections were damaged when the plug was pulled out of the socket. Yes Jim it's a separate lead with the USB connection to plug into the lappy. I have now taken the old lead out the Rav that connected the Dashcam. According to the fuse board map the cigarette lighter fuse is No19 on the panel under the dash which is fine by the looks of it? So if it's not the fuse what else could it be, is the cigarette socket Kapput
Post by davrav on Aug 24, 2022 11:11:03 GMT
Have you actually tested the fuse Paul? Maybe swap it with another of the same value just to be sure.
Post by Paulus17 on Aug 25, 2022 7:03:43 GMT
Have you actually tested the fuse Paul? Maybe swap it with another of the same value just to be sure. No David i will but get someone to have a look at it. There are no spare fuses left in the fuse box cover so will have to get some :yes:
Post by firemac on Aug 25, 2022 10:05:01 GMT
Have you actually tested the fuse Paul? Maybe swap it with another of the same value just to be sure. No David i will but get someone to have a look at it. There are no spare fuses left in the fuse box cover so will have to get some :yes: Meanwhile why not swap one with the same value out of another circuit in the box?😊
Post by davrav on Aug 25, 2022 10:11:29 GMT
No David i will but get someone to have a look at it. There are no spare fuses left in the fuse box cover so will have to get some Meanwhile why not swap one with the same value out of another circuit in the box?😊 'swot I meant above :yes:
Post by Paulus17 on Aug 26, 2022 15:36:37 GMT
No David i will but get someone to have a look at it. There are no spare fuses left in the fuse box cover so will have to get some Meanwhile why not swap one with the same value out of another circuit in the box?😊 I decided to wait Jim until i got some new fuses as the Rav isn't going to be used until the weekend and yes it was the fuse after all that The old fuse still looks ok but what could have caused it to blow in the first place and knacker the dashcam unless it's just coincidence it packed up the same time? Any road thanks once again for all your help :TU:
Post by davrav on Aug 26, 2022 16:29:52 GMT
Possible that, as the plug fell apart and any metal parts dropped into the bottom of the socket, both the socket and dashcam were shorted out I guess. That would certainly blow the fuse.
