Post by gilly on Sept 16, 2021 9:09:39 GMT
Hi
Just joined, new owner of a 2003 rav4 NRG which I bought as an 'activity' vehicle for hiking/fishing/surfing etc trips in all weathers, great condition and very pleased with her. She will only get light weekend type use so hopefully will give me plenty of life back. She was a BARGAIN at £1500 with mint interior and minor exterior wear and tear on 90,000 miles. I can't find faults thus far, clutch may need work in time and she will get a full oil service ASAP.
Looking through the history. She has had a lambda sensor, brake pipe and suspension bush replacements in her life, so not bad. 5 excellent tyres, generally very clean and agile. So Im quite excited and 'think' I got a good one.
Im ok to work on cars myself so Im here to learn and no doubt get advice when work needs to be done. Any immediate tips from those in the know would be appreciated here, thanks.
Cheers
Post by jasehutch on Sept 16, 2021 12:04:54 GMT
Hi gilly and welcome to the club
Post by firemac on Sept 16, 2021 12:08:06 GMT
Welcome to the forum! Fill in your details on your profile so we know exactly what car you have. That way we can make sure that you get the correct crap advice.😂😂😂 You have the nicest version of RAV (RAV 4.2 - that’s the second series of the model) IMHO. I’m sure you’ll enjoy it.👍
Post by bigkev on Sept 16, 2021 13:13:40 GMT
Welcome abroad, Gilly min. As Firemac says, please prolifically fill in your profile……see whit ah did there…?
Post by gilly on Sept 16, 2021 14:01:02 GMT
Welcome abroad, Gilly min. As Firemac says, please prolifically fill in your profile……see whit ah did there…? Thanks all, i think I did that before but let me know if its not showing? thanks
Post by davrav on Sept 16, 2021 14:33:30 GMT
 to the club gilly. Look after that wee RAV properly [oil changes/services and wear and tear repairs] and it should see you well for a good long while
Post by unclebob on Sept 16, 2021 16:53:51 GMT
Big welcome to the club, nice to see another 3 door on the forum 👍🏻👍🏻
Post by three5 on Sept 16, 2021 18:01:42 GMT
A big welcome gilly. Brilliant choice of vehicle. Where abouts are you based?
Post by charliefarlie on Sept 16, 2021 18:26:21 GMT
Greetings 👍👍👍👍👍👍👍
Post by unclebob on Sept 17, 2021 7:27:05 GMT
The only tip I can think of at the moment, is to take the plastic shield off the near side rear inner wheel arch, to check if the fuel filler neck is in good condition. That can be a good indicator of the cars life, as they can rust out and leak if it’s been used in heavy salted winters . If all good ..give it a clean and a coat of spray underseal . This was the filler pipe on my 107k example….all good 👍🏻
Post by gilly on Sept 20, 2021 9:42:38 GMT
A big welcome gilly. Brilliant choice of vehicle. Where abouts are you based? Thanks, Im in Newton Abbot, South Devon
Post by gilly on Sept 20, 2021 9:48:19 GMT
The only tip I can think of at the moment, is to take the plastic shield off the near side rear inner wheel arch, to check if the fuel filler neck is in good condition. That can be a good indicator of the cars life, as they can rust out and leak if it’s been used in heavy salted winters . If all good ..give it a clean and a coat of spray underseal . This was the filler pipe on my 107k example….all good 👍🏻  Thats great thank you, The previous under undersealed it, so either that's good, or they covered things up. I will check this asap. Whilst I have your ear, Particularly on the rear door, I get a loudish 'crack' noise as it engages in the anti shut mechanism. Sounds rough so I want to sort that. Is it common? normal? and is it sortable?
Post by three5 on Sept 20, 2021 9:56:10 GMT
A big welcome gilly. Brilliant choice of vehicle. Where abouts are you based? Thanks, Im in Newton Abbot, South Devon Unless you count our continental members, I reckon you are our most southerly member then. It's always useful to know who is reasonably local in an emergency. Ravasher and I only live about 4 miles apart and, when I can get hold of him, drink a lot of coffee together. ( We are also both Brummies originally! ) Your back door issue sound like a good excuse for a stripdown, cleanup and lubricate.
Post by unclebob on Sept 20, 2021 12:19:29 GMT
Back door check strap is not normally noisy…check the two 10mm bolts/nuts are tight as it goes into the back door. I have a standard check strap available, as I’ve fitted the full 90deg adapted item.
Post by davrav on Sept 20, 2021 13:01:55 GMT
Ref. 'crack' sound on back door, check around the mounting bracket for any actual cracking of the metal around it. Does sometimes happen if the door has been whipped back or strained. Other than that, as Three5 and Unclebob have suggested, strip down and lubricate - or replace if obviously damaged.
