Post by bigkev on Aug 7, 2020 18:54:26 GMT
But try not to get aw bent oot of shape, mate.......some wummin at Toyota hasn’t heard of Dot3 worries ma boobs off if somebody listens to her. You have Don.......Charlie has Don........just ask him on here, but we are more worth believing than some wummin at Toyota.....surely......? Dot5 not even relevant to this thread.
Post by unclebob on Aug 8, 2020 12:34:42 GMT
Post by Paulus17 on Aug 9, 2020 19:00:56 GMT
Cheers Bob have now ordered a couple of bottles meself
Post by unclebob on Aug 9, 2020 19:48:42 GMT
Cheers Bob have now ordered a couple of bottles meself Good brand name as well 👍🏻👍🏻
Post by Paulus17 on Aug 10, 2020 11:25:05 GMT
Post by unclebob on Aug 10, 2020 11:50:45 GMT
They Really don’t need painting as they come with a coatings on already ....yet you can’t have enough paint on brake hubs 😉😉
Post by three5 on Aug 10, 2020 12:09:06 GMT
Don’t Really need painting as they come with a coatings on already ....yet you can’t have enough paint on brake hubs 😉😉 I seem to remember Don or Kev saying that you shouldn't remove the coating when you fit the discs, just let the pads remove it over the first couple of hundred yards!
Post by unclebob on Aug 10, 2020 12:28:52 GMT
Don’t Really need painting as they come with a coatings on already ....yet you can’t have enough paint on brake hubs 😉😉 I seem to remember Don or Kev saying that you shouldn't remove the coating when you fit the discs, just let the pads remove it over the first couple of hundred yards! That’s correct ..I’ve fitted Pagid to a Lexus SC430and Toyota Aygo, the coating is gone after first trip around the block 👍🏻
Post by Paulus17 on Aug 10, 2020 13:26:51 GMT
They Really don’t need painting as they come with a coatings on already ....yet you can’t have enough paint on brake hubs 😉😉 Oh ok Bob, i thought they would have an oily coating on to clean off but apparently not. So the coating on there won't affect the new pads either? Is it worth painting the drum part though?
Post by unclebob on Aug 10, 2020 18:31:14 GMT
They Really don’t need painting as they come with a coatings on already ....yet you can’t have enough paint on brake hubs 😉😉 Oh ok Bob, i thought they would have an oily coating on to clean off but apparently not. So the coating on there won't affect the new pads either? Is it worth painting the drum part though? No harm in giving the hub area and extra coat 👍🏻
Post by Paulus17 on Aug 11, 2020 17:52:23 GMT
Well thanks to Bob for pointing me to the site that sells this fluid and to Kev for pointing me in the right direction, i had three bottles of these turn up today thinking i'd only ordered two, thought i'd got a bottle free until i rechecked the order:-X Are specsavers open yet
Post by unclebob on Aug 12, 2020 20:16:31 GMT
Mime arrived today as well ......gots a years shelf life which is not unreasonable for brake fluid .
Post by Paulus17 on Aug 12, 2020 20:33:55 GMT
Mime arrived today as well ......gots a years shelf life which is not unreasonable for brake fluid . That's good to know then Bob How often should the brake fluid be changed?
Post by unclebob on Aug 12, 2020 21:05:21 GMT
Mime arrived today as well ......gots a years shelf life which is not unreasonable for brake fluid . That's good to know then Bob How often should the brake fluid be changed? Every two years 👍🏻
Post by bothwellbuyer on Aug 14, 2020 9:07:34 GMT
That's good to know then Bob How often should the brake fluid be changed? Every two years 👍🏻 I kinda knew that but try to forget it....as the fluid in my Green Goddess is at least 6 years old and I really don't fancy bleeding the thing...specially as the brakes are so bad...rather just replace the anchor and rope!!
