Post by bothwellbuyer on Aug 14, 2020 9:08:56 GMT
Well thanks to Bob for pointing me to the site that sells this fluid and to Kev for pointing me in the right direction, i had three bottles of these turn up today thinking i'd only ordered two, thought i'd got a bottle free until i rechecked the order:-X Are specsavers open yet ![](https://i.ibb.co/BryZDMv/brakefluid.jpg) not sure, but a quick trip to Barnard castle will get you sorted.
Post by unclebob on Aug 14, 2020 9:09:54 GMT
I kinda knew that but try to forget it....as the fluid in my Green Goddess is at least 6 years old and I really don't fancy bleeding the thing...specially as the brakes are so bad...rather just replace the anchor and rope!! Job could be made easier these days with a vacuum bleeder 👍🏻
Post by Paulus17 on Sept 8, 2020 18:59:02 GMT
My brother is coming to do the brakes some time this week so is there anything else i could do beforehand, i have ordered the new pins and clips for the rears and he said he's got a pump as he's just done the brakes on his motor :TU:
Post by unclebob on Sept 8, 2020 19:21:54 GMT
Sounds like you have it covered...maybe some brake cleaner spray 👍🏻
Post by Paulus17 on Sept 9, 2020 18:06:41 GMT
Sounds like you have it covered...maybe some brake cleaner spray 👍🏻 Got it Bob :TU: so fingers crossed that all goes smoothly :yes:
Post by unclebob on Sept 9, 2020 18:22:49 GMT
Sounds like you have it covered...maybe some brake cleaner spray 👍🏻 Got it Bob ![:TU:](http://www.thesmilies.com/smilies/happy/thumbsup.gif) so fingers crossed that all goes smoothly So all you’ve got to do now is sit back and watch your brother 😄😄😉
Post by Paulus17 on Sept 9, 2020 19:25:36 GMT
Well everything is ready Bob as he's doing it tomorrow :TU: ![](https://i.ibb.co/tmQ3sJx/ravbrakeparts.jpg)
Post by davrav on Sept 9, 2020 19:38:49 GMT
Well everything is ready Bob as he's doing it tomorrow ![](https://i.ibb.co/tmQ3sJx/ravbrakeparts.jpg) Where's the tea bags Paul?
Post by three5 on Sept 9, 2020 19:45:01 GMT
Well everything is ready Bob as he's doing it tomorrow ![](https://i.ibb.co/tmQ3sJx/ravbrakeparts.jpg) Where's the tea bags Paul? I reckon that big box is full of them David, it certainly would be if I was doing the job ![;)](//storage.proboards.com/forum/images/smiley/wink.png) Paul - is the tube in the foreground Ceratec ( or similar ) grease for the pads - as recommended by Anchorman?
Post by Paulus17 on Sept 9, 2020 20:20:02 GMT
Tea bags coffee and summat a bit stronger if needed ![:P](//storage.proboards.com/forum/images/smiley/tongue.png) are all ready as well :TU: Chris it is what came with the kit and is called BremTech Pad Goo which is a "metal free paste for lubricating metal to metal braking components. Helps to eliminate brake noise/squeal." :TU:
Post by three5 on Sept 9, 2020 20:44:30 GMT
Tea bags coffee and summat a bit stronger if needed ![:P](http://www.thesmilies.com/smilies/winking/winking06.gif) are all ready as well ![:TU:](http://www.thesmilies.com/smilies/happy/thumbsup.gif) Chris it is what came with the kit and is called BremTech Pad Goo which is a "metal free paste for lubricating metal to metal braking components. Helps to eliminate brake noise/squeal." ![:TU:](http://www.thesmilies.com/smilies/happy/thumbsup.gif) Certainly does the same job as Ceratec then. I'd never used it until Anchorman did in his "how to ......" video.
Post by Paulus17 on Sept 10, 2020 6:16:41 GMT
Tea bags coffee and summat a bit stronger if needed ![:P](http://www.thesmilies.com/smilies/winking/winking06.gif) are all ready as well ![:TU:](http://www.thesmilies.com/smilies/happy/thumbsup.gif) Chris it is what came with the kit and is called BremTech Pad Goo which is a "metal free paste for lubricating metal to metal braking components. Helps to eliminate brake noise/squeal." ![:TU:](http://www.thesmilies.com/smilies/happy/thumbsup.gif) Certainly does the same job as Ceratec then. I'd never used it until Anchorman did in his "how to ......" video. Is that Anchormans video on the front brakes Chris as we are doing the rear brakes and discs :TU:
Post by three5 on Sept 10, 2020 7:05:14 GMT
Certainly does the same job as Ceratec then. I'd never used it until Anchorman did in his "how to ......" video. Is that Anchormans video on the front brakes Chris as we are doing the rear brakes and discs Yes, but the general principles of what he shows are similar. If yours has the drum-in-disk handbrakes and you remove the disks, you will probably need to adjust the handbrake afterwards.
Post by Paulus17 on Sept 10, 2020 19:35:35 GMT
Both rear discs with new pads now fitted, handbrake adjusted and also bled the whole system :TU: The two bolts holding the calipers on were a bit of a bugger to loosen but managed it without any issues. Never had time to do the fronts today but looks like they do need doing soon :yes: Mrs P and meself took it for a test drive and said she could feel the difference straight away so can't wait for the fronts to be done. ![](https://i.ibb.co/WkbXM2d/ravreardisc2.jpg) ![](https://i.ibb.co/MZvs63D/ravreardisco1.jpg)
Post by unclebob on Sept 10, 2020 20:24:22 GMT
Nice shiny new parts 😻
