Post by jasehutch on Oct 4, 2024 17:57:07 GMT
I didn't see one spider David on any of the webs but yes the hose on jet didn't touch the webs so just got wiped off with the cloths. Thinking of it now i should've left them on as it would've made a good Halloween prop in a few weeks time washed mine yesterday as well. The spiders are not keen on snowfoam! We haven't seen a photo of your new motor yet Chris 😉
Post by three5 on Oct 4, 2024 18:06:28 GMT
washed mine yesterday as well. The spiders are not keen on snowfoam! We haven't seen a photo of your new motor yet Chris 😉 I'll see what I can do Jase.
Post by Paulus17 on Oct 4, 2024 19:18:41 GMT
I didn't see one spider David on any of the webs but yes the hose on jet didn't touch the webs so just got wiped off with the cloths. Thinking of it now i should've left them on as it would've made a good Halloween prop in a few weeks time washed mine yesterday as well. The spiders are not keen on snowfoam! I couldn't be bothered to get the pressure washer out yesterday Chris, took all my effort just using the bucket and hose
Post by Paulus17 on Oct 30, 2024 11:58:21 GMT
I am finally getting around to doing summat with the TTE wheels and we are definitely going to get them refurbished but is there any way of keeping the little badge that is on the wheel as in the previous piccys and while i was sorting the nuts out that came with the wheels i noticed that four are different and one has a metal or plastic washer attached, bottom nut on it's own. Should they all have that washer on or doesn't it matter?
Post by unclebob on Oct 30, 2024 15:24:38 GMT
Have you got a close up photo of the wheel locating holes ? I suspect they are taper seat nuts unlike the LEXUS/TOYOTA flat washer type. Don’t like the look of the curved taper on the silver nuts, think the black ones look like the right ones .
Post by Paulus17 on Oct 30, 2024 16:08:43 GMT
This is the best i can get Bob. I have been told that the wheels do need the round edge rather than the flat which are on the nuts to the wheels fitted now.
Post by unclebob on Oct 30, 2024 17:11:20 GMT
Difficult to see , does it look like a taper seat ? Can you get a photo with the camera flash on 👍🏻
Post by stewpot on Oct 30, 2024 20:24:36 GMT
Hopefully a photo of my 3 door mk 1, not sure there was anything left to do to it, loved that car 🥰
Post by Paulus17 on Oct 31, 2024 11:00:23 GMT
Hopefully a photo of my 3 door mk 1, not sure there was anything left to do to it, loved that car 🥰 I never used to like the Rav 4.1 but it has grown on me over the years, nice looking 3 door Stew
Post by Paulus17 on Oct 31, 2024 11:03:36 GMT
This is with flash Bob.
Post by unclebob on Oct 31, 2024 11:09:50 GMT
Well those holes have had taper seat bolts in them. Next question does the standard RAV4 wheel nut brace fit down those holes. I ask as the wheel nuts can be bought in 19mm and 21mm…..21mm being the standard Toyota size 👍🏻
Post by Paulus17 on Oct 31, 2024 11:25:17 GMT
Well those holes have had taper seat bolts in them. Next question does the standard RAV4 wheel nut brace fit down those holes. I ask as the wheel nuts can be bought in 19mm and 21mm…..21mm being the standard Toyota size 👍🏻 I haven't a clue at this moment in time Bob, i am hoping to get the Rav in the garage next week so we can have a proper look and try the wheels on, all been well they can go off to be refurbed, then some new tyres fitted, but which ones?
Post by Paulus17 on Nov 5, 2024 13:27:50 GMT
I'm afraid Mrs P has pranged the rear passenger side corner bumper, it's only been pushed in so i have used the hot water trick and managed to push the main dents out but is still showing small dents and the paintwork is all cracked. Is it worth repairing as i can get two corners off a 2003 model, i take it they'll be the same?
Post by unclebob on Nov 5, 2024 13:47:17 GMT
I'm afraid Mrs P has pranged the rear passenger side corner bumper, it's only been pushed in so i have used the hot water trick and managed to push the main dents out but is still showing small dents and the paintwork is all cracked. Is it worth repairing as i can get two corners off a 2003 model, i take it they'll be the same? Yes the 3 door 2003 should fit okay, although get ones that have had flared arches fitted..so the clip holes are there 👍🏻 maybe keep them in stock ! 😉
Post by Paulus17 on Nov 5, 2024 14:10:43 GMT
I'm afraid Mrs P has pranged the rear passenger side corner bumper, it's only been pushed in so i have used the hot water trick and managed to push the main dents out but is still showing small dents and the paintwork is all cracked. Is it worth repairing as i can get two corners off a 2003 model, i take it they'll be the same? Yes the 3 door 2003 should fit okay, although get ones that have had flared arches fitted..so the clip holes are there 👍🏻 maybe keep them in stock ! 😉 Cheers Bob i will buy them both as they're a good price, only trouble is they are Blue so will need respraying, so how do i find the correct Black, can i buY a rattle can or three off the shelf?
