Post by Hoovie on Feb 8, 2018 12:08:36 GMT
Sat Jan 10, 2015 8:40 pm #1 By Firemac Tools and bits needed: New auxiliary power socket c/w wiring Two-wire connector block Silicon sealant Small flat-blade electrical screwdriver Standard flat-blade screwdriver Pliers – stubby & needle-nose Wire cutter/stripper (optional) Time taken: 1½ hours The socket kit. £4.99 from Cheap Accessories on eBay. It comes with 10-amp fuse and holder but this isn’t needed on the RAV as the power supply to the socket is protected by an existing fuse in the fuse box. The Full Guide: RAV 4 AUX Power Socket.pdf (571.37 KB) NOTE: No responsibility can be assumed by the RAV4 Drivers Club or the author for any injury or damage sustained as a result of following this guide. Individuals should ensure that they are competent to complete the work safely. © Firemac
