Jack Coldicott
Year: 2008
Model Spec/Trim: T-180
Engine Capacity: 2.2 D-CAT
Post by Jack Coldicott on Oct 4, 2018 9:21:09 GMT
Hi all,
I have a 2008 RAV4 T-180 D-CAT. Following a 60/70mph cruise on the motorway the other day I noticed my instant MPG gauge was dropping by 10-15mpg for a split second, then returning to a normal MPG level every 30-60 seconds, when this drop occurred, I could see a pile of black/brown smoke coming from my exhaust.
I am aware that the DPF generally goes through a cycle of cleaning itself under cruising speeds, but conscious that the above occurs every day (I travel between 40/50 mile a day). Could there by something else that is driving this issue or am I overthinking it?
Thanks
Jack
Post by bigkev on Oct 4, 2018 13:32:43 GMT
See my reply to your other thread......same checks apply.......please God, naw.......
Jack Coldicott
Year: 2008
Post by Jack Coldicott on Oct 5, 2018 14:02:52 GMT
See my reply to your other thread......same checks apply.......please God, naw....... Thankfully, no pink stuff Any other thoughts?
Post by bigkev on Oct 5, 2018 21:21:56 GMT
Hopefully no pink splashes, and a full expansion bottle, negates my fears that your particular (best ever) model of the Rav may have had the dreaded buggert cylinder head syndrome.
Respect to anybody with the courage to strip oot dashboards.......gives me the willies.
Post by davrav on Oct 5, 2018 21:46:13 GMT
Maybe EGR needs a clean out - assuming the T180 has one.
Post by bigkev on Oct 6, 2018 6:27:02 GMT
Maybe EGR needs a clean out - assuming the T180 has one. It has indeed David........see Phaeton's recent pictorial tutorial........EGR on the 180 engine soots up like a power station lum.......guid shout.
Post by charliefarlie on Oct 6, 2018 7:23:49 GMT
Maybe EGR needs a clean out - assuming the T180 has one. It has indeed David........see Phaeton's recent pictorial tutorial........EGR on the 180 engine soots up like a power station lum.......guid shout. The whole point is is it shouldn’t soot up.... My one was always clean with only the lightest coating. Bit I did run it on premium fuels. The Guys at DNA blame the whole of engine problems on that restrictive EGR. A MUST do job for this member is to strip and clean immediately. Not all failing engines send coolant out of the expansion tank.
Post by anchorman on Oct 8, 2018 6:52:44 GMT
My mate has recently run two T180s and they both do the “red arrows” thing on a frequent basis. It keeps the boy racers back a bit and is nothing to worry about.
Cleaning the EGR certainly won’t harm - his stuck open not long ago which pleased the boy racers for a short while but it’s back on form now. A can of BG244 at least once a year is a wonderful thing.
He’s got one T180 and one 150 now so that’s the end of the EGR cleaning on the latter.
Jack Coldicott
Year: 2008
Post by Jack Coldicott on Oct 13, 2018 14:30:20 GMT
Thanks all. Will take your advice and check out the EGR. Yeh I agree the t180 is a wonderful machine. Smashes most on the road (I also have it remapped to produce ~210hp, so it’s a mean machine). But such a gas guzzler!
Post by charliefarlie on Oct 13, 2018 14:36:42 GMT
Thanks all. Will take your advice and check out the EGR. Yeh I agree the t180 is a wonderful machine. Smashes most on the road (I also have it remapped to produce ~210hp, so it’s a mean machine). But such a gas guzzler! When you say remapped you mean it’s got a Lindop box in the loop ?
Jack Coldicott
Year: 2008
Post by Jack Coldicott on Oct 13, 2018 16:43:08 GMT
Thanks all. Will take your advice and check out the EGR. Yeh I agree the t180 is a wonderful machine. Smashes most on the road (I also have it remapped to produce ~210hp, so it’s a mean machine). But such a gas guzzler! When you say remapped you mean it’s got a Lindop box in the loop ? No, remapped directly through the ECU. Just finished cleaning the EGR. It was a mess. Had so much soot that I was surprised it was still running. Hopefully that’s cleared the issue. Thanks all for your advice.
Post by davrav on Oct 13, 2018 16:45:20 GMT
Wasn't aware that re-mapping the ECU was possible on these motors. Who did it?
Jack Coldicott
Year: 2008
Post by Jack Coldicott on Oct 13, 2018 16:54:20 GMT
Wasn't aware that re-mapping the ECU was possible on these motors. Who did it? www.quantumtuning.co.uk/car-remap-tuning-remapping.aspx?make=Toyota&range=Rav-4Used this link to find my local dealer. Cost me £225. To be fair I was initially remapping in the hope for better MPG gains. Gain 1-2 mpg on average probably not enough to warrant the cost but the performance gains are great. It’s a high torque engine so removing the torque limiter with the remapping has helped release the full potential of the engine.
Post by charliefarlie on Oct 13, 2018 16:58:06 GMT
When you say remapped you mean it’s got a Lindop box in the loop ? No, remapped directly through the ECU. Just finished cleaning the EGR. It was a mess. Had so much soot that I was surprised it was still running. Hopefully that’s cleared the issue. Thanks all for your advice. Whoever remapped that standard ECU is pulling your leg. It is not possible to remap the standard Denso ECU. The reason I’ve picked up and am mentioning this is because IF someone has managed to hack into your ECU it could be the cause of your problems. Messing around with the Denso ECU could completely bugger the whole lot up.
Jack Coldicott
Year: 2008
Post by Jack Coldicott on Oct 13, 2018 17:01:15 GMT
No, remapped directly through the ECU. Just finished cleaning the EGR. It was a mess. Had so much soot that I was surprised it was still running. Hopefully that’s cleared the issue. Thanks all for your advice. Whoever remapped that standard ECU is pulling your leg. It is not possible to remap the standard Denso ECU. The reason I’ve picked up and am mentioning this is because IF someone has managed to hack into your ECU it could be the cause of your problems. Messing around with the Denso ECU could completely bugger the whole lot up. I know that the ECU is locked but as part of this process they unlocked the ECU to make the changes. Not sure, but I know it’s made a difference.
