Post by Hoovie on Feb 5, 2018 15:32:38 GMT
Sat Jun 21, 2014 11:07 am #1 Uncle bob FITTING GUIDE Owners of the Rav4.2 may have noticed how scratched the silver pull handle can become, seems there are a few options, replace them with the same from Toyota, paint them or as I've done, replace them with trims off the earlier NRG model. Scratched insert trim.... To remove trim ,insert screwdriver in the bottom and gently lever out... Can get a little stuck at the top, so a bit of a wiggle.... ...and new trim fitted, fit in from the top downwards, and push in as you go... Matches the steering wheel dimples..... Part numbers are ..nearside 74646-42010 and offside 74645-42010 these are for the 3 door model but looking at the part numbers, the 5 door share the same numbers....but do check first :s_thumbsup Price is around £40 a pair as of June 2014
