Post by Hoovie on Feb 5, 2018 15:09:57 GMT
The following procedure comes from the TVSS setting instructions, which are available in the accessories section on techdoc.toyota-europe.com
NOTE: The procedure below must be followed EXACTLY for it to work. This is only for RAV4.2 Models. The same procedure does not work on other generations of RAV4s.
1) Start with Car Alarmed and you outside the car:
2) Push the “unlock” button of the remote control the Indicator lights will flash 2 times.
3) Step in the vehicle and make sure that all doors are closed completely.
4) Insert the key into the ignition key cylinder.
Wait for more than 5 seconds.
5) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON) and the Status Monitor LED will illuminate for 30 seconds.
6) While the LED is illuminated :
Open and close the driver’s door 5 times.
And then turn the key to the ACC position. LED will continue illuminating and the Indicator lights will flash 5 times.
7) To put the Ignition controlled door lock ON :
While the LED is illuminated:
Open and close the driver’s door 1 time.
Turn the key ACC-ON-ACC 1 time (Last position : ACC). the Indicator lights will flash 1 time and the LED will extinguish. END
When the procedure is done come out of the car and arm the alarm wait about a minute so the car is alarmed then un-arm it, get in the car close the drivers door and turn the ignition the car should lock and then unlock when you turn off again.
If you want to switch off the function then repeat steps 1- 6, but then do the following:
To put the Ignition controlled door lock OFF:
Open and close the driver’s door 2 times.
Turn the key ACC-ON-ACC 1 time (Last position: ACC) the Indicator lights will flash 2 times and the LED will extinguish.
Notes:
The door lock will be overruled by operating the “central lock button” or manual door knob operation.
If the Ignition is turned ON a second time the “ignition controlled door lock” will NOT operate again.
Notes:
