Post by Carol on Jul 1, 2018 13:32:37 GMT
Help , does anyone know what the aluminum unit is above the slave cylinder on a Toyota 2002 Rav4 , clutch fluid is spurting out from it , many thanks.
Post by davrav on Jul 1, 2018 14:00:17 GMT
Welcome to the club Carol. Is it clutch fluid or oil from the gearbox? Do you have or can get a photo of the general area? Others with experience of your model will be along later. In the meantime, is this a petrol or diesel RAV?
Post by jasehutch on Jul 1, 2018 15:14:46 GMT
Hi Carol , I'm sure this has come up recently and Uncle Bob or Anchorman will know the answer.. :TU:
Post by Carol on Jul 1, 2018 15:31:17 GMT
Hi , thanks for your replies,it is a 2002 diesel and definitely clutch fluid , was towed home by AA after clutch pedal went on the floor and had to lift with foot to try to pump it , AA said slave cylinder but on looking at it it is spurting from the aluminium unit above that feeds the slave.
Post by davrav on Jul 1, 2018 16:08:11 GMT
Master cylinder? Does it have a plastic reservoir on top of the casting?
Post by Carol on Jul 1, 2018 16:31:52 GMT
Master cylinder is fine, this is a small aluminum unit about 3 inches long sitting just above the slave cylinder feeding in and out of the slave by 2 small metal pipes.
Post by three5 on Jul 1, 2018 19:20:54 GMT
Hi Carol , I'm sure this has come up recently and Uncle Bob or Anchorman will know the answer.. Is this some sort of damper unit to prevent the clutch being engaged too aggressively? It would help to protect the DMF as well. If I remember correctly, my Isuzu Trooper had one, though that was pre-DMFs. It was probably intended to give the gearbox some protection as it was a very torquey engine.
Post by Carol on Jul 1, 2018 19:29:53 GMT
Thanks Chris , need to know the name of the unit to be able to sorce a replacement, anyone got the Rav4 manual?
Post by jasehutch on Jul 1, 2018 19:39:32 GMT
Post by three5 on Jul 1, 2018 19:40:53 GMT
Thanks Chris , need to know the name of the unit to be able to sorce a replacement, anyone got the Rav4 manual? Hi Carol, in your position I would give our resident parts guru, Kingo a ring in the morning and explain the problem to him. I haven't got his telephone number handy but I'm sure that Ravasher has and will pass it on to you. He has a standing order with him for front bumper end mouldings. He was telling me on Friday that Kingo's standard greeting to him is now "Morning Ash, which side this time?" It seems that his RAV has a difficult relationship with his gatepost and Mrs Ash is only encouraging it ( the gatepost )!
I've PM'd Ash and asked him to pass on the relevant telephone number.
Post by Carol on Jul 1, 2018 21:29:37 GMT
Thanks , yep that's the part , clutch hydraulic damper, you are all fantastic , just need to find one now, any ideas ?
Post by davrav on Jul 1, 2018 21:31:24 GMT
Thanks , yep that's the part , clutch hydraulic damper, you are all fantastic , just need to find one now, any ideas ? Carol, see advice from Chris [Three5] above.
Post by jasehutch on Jul 1, 2018 21:37:58 GMT
Post by unclebob on Jul 1, 2018 23:17:42 GMT
Trouble with buying a second hand one it could have the same problem crop up in a few weeks time 😟 ..and big welcome to the club 👍🏻
Post by Ravasher on Jul 2, 2018 7:50:32 GMT
😂😂 thanks Chris the gatepost will be fitted with a very thick sponge type material to stop any further knocks 🤞🏼👍🏼 This is Kingos number ask for John and he’ll be more than happy to price the part up for you and there is a small discount for members too 01978 720074
