Post by bothwellbuyer on Sept 3, 2024 8:22:24 GMT
The 5 door I intend to sell got 2 advisories - "Nearside Front Lower Suspension arm pin or bush worn but not resulting in excessive movement Rear bush (5.3.4 (a) (i))"
The garage said that as I intended to sell the car, it wouldn't be worth fixing the bushes. The offside was mentioned too. The car drives ok but there is clearly knocking going on - and I guess that would put people off. Anyone fixed this fault? Do I need to buy the lower arm, or can I just get the bush replaced? The arm seems to be around £80 each....the bush £9
I've watched a Youtube video to replace the arm, which seems to be a bit labour intensive involving loosening the subframe, or the engine mountings.
The car is listed on AutoTrader - one of the few 2007 petrol auto RAVs. No response yet..maybe too cheap lol
Post by unclebob on Sept 3, 2024 9:28:25 GMT
Just found the car in question …does seem very cheap.
Post by davrav on Sept 3, 2024 11:18:19 GMT
Presumably the arm still needs to come off to replace the bush.
Post by bothwellbuyer on Sept 3, 2024 14:59:59 GMT
Just found the car in question …does seem very cheap. Aye - I'm thinking of sorting the front bumper scrape and get the front suspension knocks done and then jack the price up. The other 2007 autos are a fair bit more £s.
Post by bothwellbuyer on Sept 3, 2024 15:02:09 GMT
Presumably the arm still needs to come off to replace the bush. Yes- you're right. So going to that length, maybe easier to fit new arms. Not a job I could take on so would need to be a garage....straight forward enough but just a lot of fiddling to do it I think.
