Post by sich1 on Sept 21, 2022 19:52:36 GMT
Hi all
its time to do some work on the rav ready for the next MOT. i need a set of front anti roll bar links, i have searched eurocarparts/carpartsforless and also the blueprint site. i get a mix of 312mm offerings and 285mm offerings! The blueprint site says 312mm (ADT38541) eurocarparts has various at 285mm ?? does anyone have a techspec sheet or experience from doing the job on a 4.2.5 D4D, which size is it ??
thanks stu
Post by unclebob on Sept 21, 2022 20:42:12 GMT
Hi all its time to do some work on the rav ready for the next MOT. i need a set of front anti roll bar links, i have searched eurocarparts/carpartsforless and also the blueprint site. i get a mix of 312mm offerings and 285mm offerings! The blueprint site says 312mm (ADT38541) eurocarparts has various at 285mm ?? does anyone have a techspec sheet or experience from doing the job on a 4.2.5 D4D, which size is it ?? thanks stu Stu if you pop a wheel off and take a measurement that would be the best option . I could measure mine but diesel/petrol could be different ☹️
Post by sich1 on Sept 21, 2022 22:05:04 GMT
thanks unclebob
sounds like a plan, are they measured middle of bolt to middle of bolt? i did think of that but not knowing where the measurement was taken from put me off it. you may be right about the possible difference between the two fuels though. another job for the weekend, along with spraying the kitchen cupboards for the Mrs.
Post by unclebob on Sept 22, 2022 0:26:33 GMT
thanks unclebob sounds like a plan, are they measured middle of bolt to middle of bolt? i did think of that but not knowing where the measurement was taken from put me off it. you may be right about the possible difference between the two fuels though. another job for the weekend, along with spraying the kitchen cupboards for the Mrs. I would think bolt centres 👍🏻
Post by unclebob on Sept 22, 2022 7:06:40 GMT
Done a bit of homework this morning …all the ARB links on euro car parts, all 5 brand choices in both petrol or diesel options are all 285mm long. Then looked up a few on eBay and also come up with 285mm…..guess measuring your ones is the only option 👍🏻
