Post by bothwellbuyer on Sept 16, 2022 11:35:44 GMT
Must be something not right? On strat from cold, the 2.0 vvti petrol starts first time and runs at 1600rpm. Once the engine is at working temp, it ticks over at 650-700rpm smoothly.
Is the fast revs normal on this engine ?
Its got air conditioning so I wondered if that caused the high revs initially??
Post by davrav on Sept 16, 2022 12:15:17 GMT
Post by firemac on Sept 16, 2022 14:35:53 GMT
Remembering all the 4.2 VVTi’s we’ve had over the years, that sounds about right. 👍
Post by bothwellbuyer on Sept 16, 2022 15:05:20 GMT
Thanks guys.....can relax now !
Post by bigkev on Sept 18, 2022 16:05:33 GMT
Wife’s three door, now gone, never wanst went as high as 1600……..1100/1200 from cold mibeez, never 1600.
Post by davrav on Sept 18, 2022 16:14:52 GMT
Wife’s three door, now gone, never wanst went as high as 1600……..1100/1200 from cold mibeez, never 1600. Smaller feet
Post by clarki on Sept 19, 2022 12:56:10 GMT
Sounds like the IAC - idle air control valve - had similar on the MR2.
Good clean with some carb cleaner and all ok again.
Post by bothwellbuyer on Sept 19, 2022 13:44:20 GMT
Sounds like the IAC - idle air control valve - had similar on the MR2. Good clean with some carb cleaner and all ok again. A pal suggested the same.
Post by unclebob on Sept 20, 2022 12:56:37 GMT
Yes mine has high idle for a short time, then returns to around 750rpm warm/hot 👍🏻 Just don’t set out in the snow at 1600rpm…it will run away with you 😉😉
