Post by widge on Jul 21, 2022 20:05:56 GMT
Hi
I do not have the moulded spare wheel cover, and the cover i have is disintegrating, It looks like the standard moulded cover also has a backing plate behind the wheel, is this necessary to fix the cover to or does the cover just clamp round the wheel somehow?
I am looking at some second hand ones and want to make sure that I get all the necessary parts.
Post by firemac on Jul 21, 2022 21:10:35 GMT
Hi I do not have the moulded spare wheel cover, and the cover i have is disintegrating, It looks like the standard moulded cover also has a backing plate behind the wheel, is this necessary to fix the cover to or does the cover just clamp round the wheel somehow? I am looking at some second hand ones and want to make sure that I get all the necessary parts. Dave You’ll need the rear mounting plate as the wheel cover clips onto it. It is a very odd fitting arrangement the first time you try it but it does work with patience. Once you’ve got it seated correctly, there’s a suitcase style toggle clamp at the bottom that secures the cover to the backing plate. You can also fit a small padlock to it to improve security.
Post by unclebob on Jul 22, 2022 17:59:13 GMT
There are many types of stretchy cover that look good on the market , some do customised logo or designs. As said above the standard cover has a backing plastic part that fixes to the metal frame. If you still have that back part of the cover ,you will see some slots at the top. Front cover hangs on them and clamps at the bottom.
Post by sich1 on Jul 23, 2022 7:58:35 GMT
pm sent with link to pictures fm my 4.2.5. probably the same part, but not 100% sure on that. hope they help.
