Post by unclebob on Jun 17, 2022 12:55:08 GMT
Aye Bob...but its been in the UK maybe since 2004; or at least registered in UK since 2004. The underside is one of the cleanest I've seen in a car this age so its the MOT (after polishing the headlamps), then off for a Dinitrol treatment. MOT first as I suspect a wee knock at the front nearside needs investigated. The front wing had a wee bit of damage at the front corner, and I noticed the front steel wheel had a lip bent + the tyre was worn at one patch - all adding up to that corner needing checked for alignment too. I didn't rralise that it had overdrive!! Was that normal on the 4.2 autos ? Yes they all got a little button on the gear knob 😎
Post by bothwellbuyer on Jun 20, 2022 21:21:48 GMT
Aye Bob...but its been in the UK maybe since 2004; or at least registered in UK since 2004. The underside is one of the cleanest I've seen in a car this age so its the MOT (after polishing the headlamps), then off for a Dinitrol treatment. MOT first as I suspect a wee knock at the front nearside needs investigated. The front wing had a wee bit of damage at the front corner, and I noticed the front steel wheel had a lip bent + the tyre was worn at one patch - all adding up to that corner needing checked for alignment too. I didn't rralise that it had overdrive!! Was that normal on the 4.2 autos ? Yes they all got a little button on the gear knob 😎 ooh a new toy. It has a wee button next to the gear lever too...still to try that.
Post by unclebob on Jun 21, 2022 13:27:57 GMT
Yes they all got a little button on the gear knob 😎 ooh a new toy. It has a wee button next to the gear lever too...still to try that. Little black button on the consul, let’s you take it out of park when keys are out the ignition 👍🏻
Post by bothwellbuyer on Jul 29, 2022 12:09:47 GMT
wee update, in case I forgot to post. The car passed the MOT. Just an advisory on rear brake pads thin. Booked in to get rear pads changed next week, and handbrake shoes checked. Also change tranmission oils.
