Post by bolo1957 on Mar 6, 2022 17:38:17 GMT
hi im having a problem with the key fob not being detected by my 2007 rav 4 . the car has been off the road for a few months and when i went to start it i got the message "key not deteceted" i have put new batterys in both fobs and also put a brand new battery on the car but the problem persists , any help or advice would be most appreciated
Post by shcm on Mar 6, 2022 18:39:15 GMT
Does the car lock/unlock with the fob, either by having the fob on your person and touching the door handle or by pressing the lock/unlock button on the fob?
When you depress the clutch to start, the lamp in the start button should turn from orange to green (provided the fob is actually inside the vehicle). If the lamp stays orange, try holding a fob right next to the start button (as close as you can get it). Does the lamp then turn green? Will the car start then?
Post by three5 on Mar 6, 2022 19:31:02 GMT
Does the car lock/unlock with the fob, either by having the fob on your person and touching the door handle or by pressing the lock/unlock button on the fob? When you depress the clutch to start, the lamp in the start button should turn from orange to green (provided the fob is actually inside the vehicle). If the lamp stays orange, try holding a fob right next to the start button (as close as you can get it). Does the lamp then turn green? Will the car start then? I had a not dissimilar situation on my 2008 keyless XT5. The car was off the road for 3 months after I had an operation that barred me from driving. When I went to start it the key was not detected so I went and got the spare key from the house. That wasn't detected either, but it must have been 5 years since the battery in the second key was changed, so it wasn't totally surprising. I made a cuppa and changed both key batteries. I tried to open the car again and it still wouldn't work. Key batteries removed for test, all well as far as I could tell but I put another new battery in one key and took it out to the car. This time it worked. Ever since I've wondered if it didn't like two detectable keys in range at the same time. It's too hard for me!
Post by shcm on Mar 6, 2022 20:12:38 GMT
As far as I know, there's never been anything like a re-sync procedure with the Toyota keys. I've never had cause to find out anyway, but I'd do something like multiple lock button presses in an attempt to re-sync. It's also not beyond the bound of possibility for the fob not to reset properly (or do a partial reset) after a battery change. I've not had that one for years either, but the thing there is to leave the fob battery out for several minutes when you change it, or perhaps I should say if the fob doesn't work after you've changed the battery, take the battery out again and leave for several minutes, before replacing.
I've had "key not detected" when the key's been in a pocket with a phone etc.
Post by bolo1957 on Mar 7, 2022 19:37:04 GMT
thanks all for your help , nothing happens when i try to unlock doors or when im in the vicinity of the car ,as it did before . i followed a friends advice and actually pressed the start button with the fob itself and hey presto it all came to life and started . But even though the engine was running the "key not detected "message is still there . turned off the engine and back to no responce from the fobs
Post by shcm on Mar 8, 2022 7:55:48 GMT
Short answer:
While it's not impossible that the UHF (see below) transmitter part of both keys has failed, it's probably unlikely.
It's highly likely that there's a problem with the UHF door locking receiver and/or with its connection to the certification ECU. The UHF receiver is located behind the trim between the C and D post, if I remember correctly. Think it's nearside - can't exactly remember without looking.
OR
The car UHF receiver is being blocked by a nearly radio source (possibly much high power than the key can produce) on the same or a close frequency. To attempt to check that, move the car a mile or so and try again. If it's this though, often getting the key as close as possible to the UHF receiver can sometimes unlock the car.
Long answer:
The system consists of the following (explanation over simplified):
There are two transmit and receive paths in the system. I'll call them LF and UHF. The LF part is a very short range path. In fact the LF part is more like a very weakly coupled transformer action rather than a "conventional" radio transmission. The LF part is very similar to the transponder "pill" system for security, often found in "conventional" keys.
The UHF part is a "standard" radio transmission. It's the path that's used when you press a button on the fob to lock/unlock the car.
There are LF transmit antennas in the car door handles, one in the back of the central "cubby" box and one just behind the rear seat. The start button also contains an LF antenna, that's capable of both transmission and reception to/from the key fob.
As stated the car has one UHF receiver.
The key is capable of transmitting on UHF and receiving on LF. The LF part in the key also acts as a transponder "pill".
The "keyless" entry and internal key detection works like this:
You walk up to the car and pull the handle. Pulling the handle kicks the car into transmitting via the LF antenna in the door handle. If the key hears the correct LF transmission, it transmits back to the car on UHF. The UHF transmission is picked up by the UHF receiver in the car and the car unlocks.
Once in the car, the car sends transmissions on the internal LF antennas at regular intervals (pings the key). If the key hears those transmissions, it responds to the car on UHF. You can often see the led flashing on the key, as it responds to these "pings". This way, if the key responds on UHF, to a ping from the internal LF car antennas and the car hears the key on UHF, the car then "knows" the key is in the vehicle.
There will be similar "pings" when you attempt to start the vehicle and of course if the car hears no response on UHF at this point, you'll get "key not detected".
All the above is of course all dependant on a good-ish battery in the key. If you've a duff key battery, you're stuffed. So there's a backup provided. The key also acts like a "conventional" transponder system. As I said the LF path is more like a transformer action, so you can transfer a small amount of data and power across it (enough to power a transponder), if the two "antennas" (the LF "antenna"/coil in the key and the antenna in the car start button) are very close to one another. This is what's happening when you place the key next to the start button. The key and car are communicating on LF only.
As the LF path works to start the car, but you can't unlock the car with the key, by just by pressing the fob button (i.e. not using "keyless"), then it's highly likely there's a problem on the UHF side. As both keys don't work it's likely the problem is in the UHF receive path.
Post by bolo1957 on Mar 11, 2022 11:20:41 GMT
thanks again will have another go on the weekend , you mention when you pull the handle it should activate and i dont know if this is relavant , but it used to unlock automatically as i walked towards the car with the fob in my pocket .both fobs have brand new batteries in them as does the car have a brand new battery fitted , thanks again your help is most appreciated
Post by shcm on Mar 11, 2022 12:59:38 GMT
OK, being pedantic, it will unlock if you put your fingers behind the handle without pulling. The Toyota system shouldn't be unlocking as you walk up to it. On owning 4 vehicles with the system, I've never encountered it doing that. Maybe a previous owner has ****ed with it.
Could the unlock button be being inadvertently pressed in your pocket?
Some vehicles (not Toyota, that I know about) in the distant past had badly designed keys where an electrostatic discharge from the person's clothing would cause the key to transmit and thus the vehicle to unlock. e.g. Nylon underwear!
Post by bolo1957 on Mar 15, 2022 18:53:08 GMT
thanks again i see what you mean it was probaly as i put my hand on the handle . things have slightly improved in that if i hold the fob close to the push button it comes to life and allows me to start the car but absolutely no responce from the lock or unlock buttons to lock the car
ravjeff
Model Spec/Trim: GLX
Engine Capacity: 2.5L
Post by ravjeff on Mar 23, 2022 22:39:44 GMT
Hi bolo1957 please have you an update about your snag?
Post by bolo1957 on Mar 27, 2022 17:42:14 GMT
i bought some more battries for the fobs incase the ones i previosly bought were not strong enough , i had no joy with that , i also tried somthing i saw on youtube where you dissconnect the battery then connect or touch together the negative lead to the positive lead . this they say will reset the cars settings but it still didnt work , i think my next move is an auto electrician
Post by bolo1957 on May 2, 2022 17:50:35 GMT
been working away so havnt had chance to have it looked at , but was wondering if theres a fuse that governs the key fob funtion , any help or advice would be most appreciated
Post by bolo1957 on Jul 1, 2022 14:40:54 GMT
havent solved it but a useful video is on youtube(Toyota Rav4 keyless Entry & Start not working... Fault finding and repair.) it shows that his problem was water ingress through the roof bars running down to the wiring connectors by the drivers door foot well , mine to shows signs of ingress and i even had a wire that had come out of one of the connectors which i reconnected and got two beeps was hoping this solved it but no such luck , the good news is it sailed through its mot with no advisories and its been parked up in my garden for months so i wasnt exspecting that
Post by bolo1957 on Sept 11, 2022 11:57:56 GMT
back on the case ,car has been standing for the last few months decided to try again , thought that because i had water ingress through the roof rails water might have got into the uhf reciever ,the trouble is i cant find it anywhere , any help would be most appreciated
Post by bolo1957 on Sept 11, 2022 12:05:23 GMT
found it but all looks dry
