Post by dangroves on Feb 23, 2022 18:40:37 GMT
Evening All
I have found countless noise/whine related posts but none that seem to match my issue - 2005 3 door t/diesel.......from just under 2k to 3.5k (not been any higher) it initially sounded like turbo whistle but it sounds much more like electrical interference......but radio is deffo off. Reduces slightly at constant throttle - power/pull seems fine.
Thanks in advance
Dan
Post by jasehutch on Feb 24, 2022 6:43:12 GMT
Hi Dan and welcome to the club..👍 I had the same model Rav as you and never experienced or have heard of that. Are you sure it's not turbo related ?
Post by unclebob on Feb 24, 2022 10:57:49 GMT
Welcome to the forum 👍🏻
Post by bigkev on Feb 24, 2022 15:09:50 GMT
Was there not once a diesel filter or pump noise issue reported on Tumbleweed Forum…? Sorta low whistling noise mistaken for turbo…?
Excuse manners….welcome to this nub of us clutters.
Post by three5 on Feb 24, 2022 17:24:01 GMT
Was there not once a diesel filter or pump noise issue reported on Tumbleweed Forum…? Sorta low whistling noise mistaken for turbo…? Excuse manners….welcome to this nub of us clutters. Wow! your memory is a lot better than mine Big Fella! :TU: It certainly rings a bell with me. I may have this wrong but I seem to recall it being a gubbered filter and changing it cured the problem. It would be a fairly cheap item to change ( DIY ) and couldn't possibly do any harm.
Post by jasehutch on Feb 24, 2022 20:34:46 GMT
Now you mention it , wasn't that a burping kind of noise though and rectified by fitting a modified fuel filter head ?
