fossie
Primary Vehicle: Rav4
Year: 2007
Model Spec/Trim: Xt4
Engine Capacity: 2.0
Post by fossie on Jan 18, 2022 22:59:46 GMT
The rumbling sound became a resonance and a vibration above 40 mph . On checking the rear propshaft ujs are goosed . 2007 petrol manual , will ther models fit and how easy to source?
Post by charliefarlie on Jan 20, 2022 17:30:29 GMT
The rumbling sound became a resonance and a vibration above 40 mph . On checking the rear propshaft ujs are goosed . 2007 petrol manual , will ther models fit and how easy to source? With respect I’m puzzled at your question. 👍👍
fossie
Year: 2007
Post by fossie on Jan 20, 2022 19:49:32 GMT
I can see the puzzlement.....it is meant to read what other models fit ? As in everytime I find a 2007 -12 one for sale its for a diesel version , or a 3.5l . Obviously the propshaft be may be different lengths for different variants .
I have found a listing for £150 + p&p for a 2.0 4x4 as required though it looks "used" it comes with a 30 day warranty so is better than mine , However for £215 a new one for a 3.5 or ddiesel can be attained.
Post by davrav on Jan 20, 2022 21:38:39 GMT
No 3.5l petrol RAVs in the UK AFIK Surely there must be some 4.3 petrol RAVs being broken? Anyone know if the 4.3 diesel is the same as the petrol version?
Post by charliefarlie on Jan 20, 2022 21:49:18 GMT
I can see the puzzlement.....it is meant to read what other models fit ? As in everytime I find a 2007 -12 one for sale its for a diesel version , or a 3.5l . Obviously the propshaft be may be different lengths for different variants . I have found a listing for £150 + p&p for a 2.0 4x4 as required though it looks "used" it comes with a 30 day warranty so is better than mine , However for £215 a new one for a 3.5 or ddiesel can be attained. Try a PM to Kingo on this forum. He’s the parts master 👍👍
Post by unclebob on Jan 20, 2022 23:31:26 GMT
Thinking about this a used prop could be just as bad, or could fail soon. Why not get your one rebuilt . Could be a propshaft reconditioner in your area .
Post by unclebob on Jan 20, 2022 23:35:52 GMT
fossie
Year: 2007
Post by fossie on Jan 21, 2022 8:53:21 GMT
Thanks for that , this is one that I found but in compatible vehicles it can up in red as not compatible ....could just be seller being on safe side, or glitch.. Either way I bought the used one a we need vehicle back on the road as it is not safe to use at the moment , the vibes are so much worse! Expedience over frugalence unfortunately . thanks for your help.
Post by unclebob on Jan 21, 2022 12:25:35 GMT
Years ago you could replace U/J joints on a propshaft, as long as the joint cups had circlips at the ends . Guess you’ll find that out when the used one arrives 👍🏻
fossie
Year: 2007
Post by fossie on Jan 21, 2022 20:08:54 GMT
Uncle bob , you are right it is a gamble ,but I can check it before I fit it .... There is a month warranty so hopefully a decent test can be attained. but the machine is needed ASAP. My Rav spent 3/4 of its life in the Shetlands and it shows , coupled with our usage I believe a replacement must be better. Once swapped I can recon the old one possibly, depending on damage.. I'll let you know if an I told you know , or a FairPlay emoji is appropriate 😄
Post by unclebob on Jan 21, 2022 20:21:52 GMT
I watched a YouTube clip of how to change the U/J on a USA mk3 RAV4. Although it has a pinched outer cup it can be converted to inner circlip. This was the part number they quoted (but needs to be double checked). www.actionmachineinc.com/products/430-8Don’t think I would let him work on my car but you get an idea of the job 🤔….
