Post by Mb2t on Sept 19, 2021 10:49:56 GMT
I am looking for a battery charger. I mainly use it for charging the caravan battery (110AH) and was looking for something good but cheap and cheerful. I know about Ctek (60-70gbp) but that is more than i wanted to spend.
Any recommendations?
Many thanks
Post by philip42h on Sept 19, 2021 11:57:08 GMT
I'm not entirely sure that something "cheap and cheerful" will be entirely "good" for what you want. Presumably, for a caravan battery, you want something that will charge it again once you've run it down - as opposed to something that will help to maintain the charge on a car battery? So, for a 110AH battery, a 1A charger that would take 110 hours to recharge the battery might not be so good? A Ctek 5 or Noco Genius 5 (5A chargers) would do the job quite well - but at a price - and their 10A equivalents would do the job even better (at an even higher price). Halfords do a Ring RSC806 6A Smart Battery Charger at £40 which might be a reasonable compromise ... ?
Post by Mb2t on Sept 19, 2021 12:12:41 GMT
I'm not entirely sure that something "cheap and cheerful" will be entirely "good" for what you want. Presumably, for a caravan battery, you want something that will charge it again once you've run it down - as opposed to something that will help to maintain the charge on a car battery? So, for a 110AH battery, a 1A charger that would take 110 hours to recharge the battery might not be so good? A Ctek 5 or Noco Genius 5 (5A chargers) would do the job quite well - but at a price - and their 10A equivalents would do the job even better (at an even higher price). Halfords do a Ring RSC806 6A Smart Battery Charger at £40 which might be a reasonable compromise ... ? Thanks! From time to time i take the battey out of the caravan (for example in winter, when it is not used) and put it in the garage on charge, so i need it to charge it and maintain. I had a charger from years ago, but it packed up and need replacing. The conclusion i am drawn to is better spend a few more pounds and get a known quantity such as the Ctek. Thank you
Post by sich1 on Sept 19, 2021 13:38:55 GMT
i have a ctek 5 and have no issues so far using it on a 75 AH battery, shop around for a good price.
Post by bigkev on Sept 19, 2021 15:20:46 GMT
I'm not entirely sure that something "cheap and cheerful" will be entirely "good" for what you want. Presumably, for a caravan battery, you want something that will charge it again once you've run it down - as opposed to something that will help to maintain the charge on a car battery? So, for a 110AH battery, a 1A charger that would take 110 hours to recharge the battery might not be so good? A Ctek 5 or Noco Genius 5 (5A chargers) would do the job quite well - but at a price - and their 10A equivalents would do the job even better (at an even higher price). Halfords do a Ring RSC806 6A Smart Battery Charger at £40 which might be a reasonable compromise ... ? Thanks! From time to time i take the battey out of the caravan (for example in winter, when it is not used) and put it in the garage on charge, so i need it to charge it and maintain. I had a charger from years ago, but it packed up and need replacing. The conclusion i am drawn to is better spend a few more pounds and get a known quantity such as the Ctek. Thank you Menachem…..if you want to try a C-tek before you buy I could send mine down furra couple of weeks. Best bite the bullet right enough…..you can leave good chargers on indefinitely whereas cheapo ones can do more harm than good.
Post by charliefarlie on Sept 19, 2021 16:07:55 GMT
Another vote for Cetek. Used on Motorhome Caravan abs several cars.
Post by anchorman on Sept 19, 2021 17:31:16 GMT
Post by bigkev on Sept 20, 2021 8:41:40 GMT
“Can’t be beaten…..currently…” Oh the banter…!
Post by unclebob on Sept 20, 2021 8:59:19 GMT
I have two on the go Ctec and Optimate. Originally had just the Optimate and charged the Lexus/RAV4 no problem, then the lockdown came and the big Renault master battery went flat so got a more powerful Ctec to handle that .
Post by Mb2t on Sept 26, 2021 9:41:09 GMT
Thanks all - Got the Ctek one, seem to work! :TU:
Post by unclebob on Sept 26, 2021 17:30:41 GMT
Thanks all - Got the Ctek one, seem to work! Great choice ….as the old saying goes "you get what you pay for" 😉😉
Post by jasehutch on Jan 29, 2022 10:12:29 GMT
Went out and bought a Ctek MXS 5.0 yesterday..😊
Post by davrav on Jan 29, 2022 10:50:18 GMT
Went out and bought a Ctek MXS 5.0 yesterday..😊 Good choice Jase - you won't be disappointed. SLK currently attached to mine.
Post by Mb2t on Jan 29, 2022 12:12:53 GMT
We were actually away... and just Came back . Before we went i charged the battery with the Ctek to full capacity. Checked today and the voltage went down to 11.75V, car started no issue. I am happy with this charger.
