Post by unclebob on Dec 19, 2020 10:56:52 GMT
Post by unclebob on Dec 19, 2020 10:59:11 GMT
Post by davrav on Dec 19, 2020 11:02:41 GMT
Depends how long it has been driven with the gearbox issue - box could be toast.........
Post by firemac on Dec 19, 2020 11:06:15 GMT
Yep, that's the one, Bob. They're very good.
Reading the sller's comments, I'd be wary. He says the gear changes are harsh but if they've continued to drive it, the box could be near to self-destruction. Apparently driving after the fault has become evident is a real no-no.
IMHO, the seller should get the ECU re-flashed and then he could sell it as a properly running vehicle. That assumes that it is the ECU issue and not something else.
Post by unclebob on Dec 19, 2020 20:38:29 GMT
Trouble is it could of had the ECU done already and the sellers keeping quite 🤔🤔 New box is double the current asking price !
Post by bothwellbuyer on Dec 19, 2020 22:00:55 GMT
jeez....tempted
Post by firemac on Dec 19, 2020 23:46:03 GMT
Trouble is it could of had the ECU done already and the sellers keeping quite 🤔🤔 New box is double the current asking price ! True, Bob, but if he has then it was too late because he says that the changes are still rough.
Post by unclebob on Dec 20, 2020 0:59:08 GMT
Should be able to see if the ECU bolts have been removed 🤔
Post by firemac on Dec 20, 2020 11:28:52 GMT
Should be able to see if the ECU bolts have been removed 🤔 Cars like this are cheap for as reason. I'd pass. :yes:
Post by unclebob on Dec 20, 2020 13:20:54 GMT
Should be able to see if the ECU bolts have been removed 🤔 Cars like this are cheap for as reason. I'd pass. Agree ... It’ll make a good project for somebody 👍🏻
