Post by Hoovie on Feb 3, 2018 14:27:01 GMT
Diesel Fuel Filter Change - RAV4.3 Hope you can understand my Derbyshire accent! Posted on behalf of Anchorman
Post by clarki on Dec 17, 2018 20:38:39 GMT
That's brilliant. Going to give this a go over the xmas break. Don't think my Rav's fuel filter has been changed for a couple of years now.
Post by bigkev on Dec 18, 2018 15:25:04 GMT
That's brilliant. Going to give this a go over the xmas break. Don't think my Rav's fuel filter has been changed for a couple of years now. Got a vice Clarki min.....? Handy to have it clamped after removal as nut hellya tight. Wear gloves obviously. Showed Anchorchap how to do mine couple of times.........fine silt both times very evident. Worth doing for sure.
Post by phaeton on Dec 18, 2018 15:29:15 GMT
that's one clean engine bay, somebody has too much time on their hands
Post by charliefarlie on Dec 18, 2018 18:01:22 GMT
Has someone got a bad arm ??
Post by clarki on Dec 18, 2018 22:05:44 GMT
That's brilliant. Going to give this a go over the xmas break. Don't think my Rav's fuel filter has been changed for a couple of years now. Got a vice Clarki min.....? Handy to have it clamped after removal as nut hellya tight. Wear gloves obviously. Showed Anchorchap how to do mine couple of times.........fine silt both times very evident. Worth doing for sure. Looking forward to using my new vice, in my new workshop. It's the small things!!
Post by clarki on Dec 19, 2018 10:24:02 GMT
Was all set to order a bosch filter from opie oils this morning but it doesn't look like you get a new bottom seal with it. Emailed them to clarify but don't think the fella could be bothered checking and suggested a febi?? filter instead. Looking elsewhere the bosch filters do seem to come with both top and bottom seals. A few quid more but if its required a no-brainer, right??
Any opinions, experience, alternatives. Many thanks.
Post by phaeton on Dec 19, 2018 10:35:56 GMT
Febi are OEM on VW/Audi group so should be good
Post by charliefarlie on Dec 19, 2018 17:45:15 GMT
Was all set to order a bosch filter from opie oils this morning but it doesn't look like you get a new bottom seal with it. Emailed them to clarify but don't think the fella could be bothered checking and suggested a febi?? filter instead. Looking elsewhere the bosch filters do seem to come with both top and bottom seals. A few quid more but if its required a no-brainer, right?? Any opinions, experience, alternatives. Many thanks. Clarkie I gorra nev vice !! Great big bugger I had given to me by a mate who said it was to big... It is the small things !!!! Tools........... That’s what it is.......
Post by oilman on Dec 20, 2018 13:33:37 GMT
Was all set to order a bosch filter from opie oils this morning but it doesn't look like you get a new bottom seal with it. Emailed them to clarify but don't think the fella could be bothered checking and suggested a febi?? filter instead. Looking elsewhere the bosch filters do seem to come with both top and bottom seals. A few quid more but if its required a no-brainer, right?? Any opinions, experience, alternatives. Many thanks. Hi I'm not sure why you think I didn't bother to check, but I did and the Bosch one didn't have the bottom seal listed, from memory, the Mahle didn't either, only the Febi one had the bottom seal listed, hence me suggesting that one. I was very busy when you asked, so didn't have the chance to call Bosch or Mahle and could only go off the information that we were given by them, so that is why I suggested the Febi as it had both seals. Cheers Tim
Post by three5 on Dec 20, 2018 16:05:49 GMT
Was all set to order a bosch filter from opie oils this morning but it doesn't look like you get a new bottom seal with it. Emailed them to clarify but don't think the fella could be bothered checking and suggested a febi?? filter instead. Looking elsewhere the bosch filters do seem to come with both top and bottom seals. A few quid more but if its required a no-brainer, right?? Any opinions, experience, alternatives. Many thanks. Clarkie I gorra nev vice !! Great big bugger I had given to me by a mate who said it was to big... It is the small things !!!! Tools........... That’s what it is.......  Charlie, beautifully tidy workshop fella! Is it concrete sections with the insulation stuck on the inside? If so, what did you use to fix the Kingspan to the concrete? I'm just tackling the same issue so the advice would be welcome!
Post by unclebob on Dec 20, 2018 16:13:37 GMT
Was all set to order a bosch filter from opie oils this morning but it doesn't look like you get a new bottom seal with it. Emailed them to clarify but don't think the fella could be bothered checking and suggested a febi?? filter instead. Looking elsewhere the bosch filters do seem to come with both top and bottom seals. A few quid more but if its required a no-brainer, right?? Any opinions, experience, alternatives. Many thanks. Clarkie I gorra nev vice !! Great big bugger I had given to me by a mate who said it was to big... It is the small things !!!! Tools........... That’s what it is.......  Nice man cave Charlie 👍🏻👍🏻
Post by clarki on Dec 20, 2018 17:41:32 GMT
Thanks. Will go with Febi. Just checking, never heard of them before.
Post by clarki on Dec 20, 2018 18:02:27 GMT
Was all set to order a bosch filter from opie oils this morning but it doesn't look like you get a new bottom seal with it. Emailed them to clarify but don't think the fella could be bothered checking and suggested a febi?? filter instead. Looking elsewhere the bosch filters do seem to come with both top and bottom seals. A few quid more but if its required a no-brainer, right?? Any opinions, experience, alternatives. Many thanks. Clarkie I gorra nev vice !! Great big bugger I had given to me by a mate who said it was to big... It is the small things !!!! Tools........... That’s what it is.......  Correct. Time for a new section on the forum...Tools. 1st thread, show us your vices. Although right now for me that would be mince pies lol
Post by roger37 on Dec 26, 2018 18:27:04 GMT
done this filter to-day....hope the bad arm is,nt catching....will my car run on fumes now?
