Post by sich1 on Nov 9, 2020 14:55:00 GMT
Hi all
does anyone have a technical doc showing the lower suspension parts ?
thanks in advance stu
Post by unclebob on Nov 9, 2020 15:00:35 GMT
Hi all
What job are you going to do 🤔
Post by widge on Nov 9, 2020 15:03:00 GMT
Hi all
I have a Haynes manual (courtesy of jasehutch) it is not very clear, but is there anything in particular that you need to see?
Post by unclebob on Nov 9, 2020 15:13:36 GMT
Here you go Stu....
Post by sich1 on Nov 9, 2020 15:24:33 GMT
its at the garage having a broken rear spring replaced. but the control arm is so badly corroded it was not possible to remove some of the bolts. now iam looking for a new control arm for them to fit.
thanks all for the pics and help.
stu
Post by widge on Nov 9, 2020 15:46:07 GMT
its at the garage having a broken rear spring replaced. but the control arm is so badly corroded it was not possible to remove some of the bolts. now iam looking for a new control arm for them to fit. thanks all for the pics and help. stu I have bought second hand parts from these people before, a little bit of a trek from you, but info might be useful if you have nobody closer. Toyota Spares Nottingham Ltd Unit 1, Victoria Works, 57 High Church St, New Basford, Nottingham NG7 7JP, United Kingdom +44 115 874 4933 maps.app.goo.gl/mPjGRehwPsLfDsDw7
Post by unclebob on Nov 9, 2020 15:52:47 GMT
its at the garage having a broken rear spring replaced. but the control arm is so badly corroded it was not possible to remove some of the bolts. now iam looking for a new control arm for them to fit. thanks all for the pics and help. stu What the main arm behind the Brake hud or the bars that go back to the diff subframe ?
Post by sich1 on Nov 9, 2020 22:45:41 GMT
its the lower suspension arm. my bad discription.
tks for that widge
stu
Post by unclebob on Nov 10, 2020 11:39:26 GMT
Seeing how the coil spring is located I’m surprise the garage didn’t try to compress the spring with clamps, as another option to get it out without damaging other components ??
Post by jasehutch on Nov 10, 2020 13:22:32 GMT
Apart from the drop links I'm sure I didn't have to unbolt anything else..
