Post by bigkev on Dec 26, 2019 7:44:44 GMT
It is flat captive washer type, Bob/Mike.......those alloys also best ever, made in That Italy by Ronal, still very much in business. Do you know what size? 12mm, 10mm, length? Got a picture? If not no big deal, I'll soon find out. Ebay search......Toyota Captive Washer Wheel Nuts.......size there. The hex is choice of 19 or 21mm......I always use 21....better for torquification imho. M12 x 1.5........19/21mm hex.
Post by unclebob on Dec 26, 2019 9:50:50 GMT
Fuel filler pipe is back at the tank end, remove near side rear wheel, you’ll see a plastic cover on the inner wing, remove cover (10mm bolts) and inspect condition of fuel filler pipe, if all good coat in wax oil and refits cover .
Post by davrav on Dec 26, 2019 9:56:13 GMT
Any plastic to metal stickiness required use either Tigerseal or Sikaflex. Prefer Tigerseal myself but can be messy unless carefully masked off and any excess cleaned off with white spirit before set.
mikegml
Primary Vehicle: RAV4 VVTi 2.0 3 door
Year: 2005
Post by mikegml on Dec 26, 2019 10:21:03 GMT
Fuel filler pipe is back at the tank end, remove near side rear wheel, you’ll see a plastic cover on the inner wing, remove cover (10mm bolts) and inspect condition of fuel filler pipe, if all good coat in wax oil and refits cover . :TU:
mikegml
Year: 2005
Post by mikegml on Dec 26, 2019 10:22:23 GMT
Do you know what size? 12mm, 10mm, length? Got a picture? If not no big deal, I'll soon find out. Ebay search......Toyota Captive Washer Wheel Nuts.......size there. The hex is choice of 19 or 21mm......I always use 21....better for torquification imho. M12 x 1.5........19/21mm hex. Cheers. I did a Ebay search and saw that but didn't trust it. In fact you get a few different choices to make it even more confusing. Rather hear it from the horses mouth.
Post by jasehutch on Dec 26, 2019 11:01:13 GMT
These are the fuel filler pipes Bob was referring to. :TU:
Post by jasehutch on Dec 26, 2019 11:03:17 GMT
mikegml
Year: 2005
Post by mikegml on Dec 26, 2019 11:13:43 GMT
These are the fuel filler pipes Bob was referring to. Thanks. I'll check that out. However, the MOT history mentions as an advisory in 2017 that the "offside front brake pipe slightly corroded" Is this the same pipe?
Post by firemac on Dec 26, 2019 11:18:29 GMT
These are the fuel filler pipes Bob was referring to. Thanks. I'll check that out. However, the MOT history mentions as an advisory in 2017 that the "offside front brake pipe slightly corroded" Is this the same pipe? No, the fuel filler is behind the N/S/R wheel.
On our first RAV 4.2 (02- reg), every MOT mentioned one or other of the brake pipes showing corrosion. Subsequent investigation never found any and I'm convinced that the dealer was just pissed because I didn't let them grease the brake unions at each service!
mikegml
Year: 2005
Post by mikegml on Dec 26, 2019 11:21:01 GMT
On our first RAV 4.2 (02- reg), every MOT mentioned one or other of the brake pipes showing corrosion. Subsequent investigation never found any and I'm convinced that the dealer was just pissed because I didn't let them grease the brake unions at each service! Yeah you're right I got a bit confused there. Anyway I'll check it out.
mikegml
Year: 2005
Post by mikegml on Dec 26, 2019 11:22:20 GMT
And these are the side bar end caps.. Cheers. I've PM'd you. or you can PM me let me know how much you want if you're to sell.
Post by jasehutch on Dec 26, 2019 11:40:01 GMT
Hi Mike , I have replied to your message. The best mod I have done to my Rav is adding cruise control ! Uncle Bob originally steered me in the right direction with his ‘how to’ post and all you need is a steering wheel off eBay with the cruise control stalk fitted.. Mine cost the grand total of £40.
Post by charliefarlie on Dec 26, 2019 12:59:10 GMT
Greetings 👍👍👍👍
mikegml
Year: 2005
Post by mikegml on Dec 26, 2019 16:10:35 GMT
Hi Mike , I have replied to your message. The best mod I have done to my Rav is adding cruise control ! Uncle Bob originally steered me in the right direction with his ‘how to’ post and all you need is a steering wheel off eBay with the cruise control stalk fitted.. Mine cost the grand total of £40. I've replied back mate. Just let me know how much and how you want paying and I'll sort it. The Cruise Control I suppose is another item on my 'wish list' especially if it's a case of just plug and play.
Post by bigkev on Dec 26, 2019 16:47:57 GMT
Hi Mike , I have replied to your message. The best mod I have done to my Rav is adding cruise control ! Uncle Bob originally steered me in the right direction with his ‘how to’ post and all you need is a steering wheel off eBay with the cruise control stalk fitted.. Mine cost the grand total of £40. I've replied back mate. Just let me know how much and how you want paying and I'll sort it. The Cruise Control I suppose is another item on my 'wish list' especially if it's a case of just plug and play. Jase......in reply to your question......YES.......£300.00 each a bit steep........
