dazza
New Member
Post by dazza on Nov 25, 2022 16:00:27 GMT
Hi,
I've got a 2004 Rav4 which has been totally reliable since we got it 5 or 6 years ago. The other day I was driving home and noticed that the clock had reset itself to 1:00 - I thought maybe I'd pressed a button by mistake while driving so I went to turn on the interior light to check and that didn't work either. Once I got home I got out and went to lock the doors with the keyfob but it didn't work at all - no flashing indicators and the doors remained unlocked.
I've recently changed the battery in the keyfob and the red light works when I press the buttons so it must be something else.
On further using the car I've noticed that the clock resets itself to 1:00 every time I drive it.
I read somewhere that sometimes everything can go out of sync and that removing a battery terminal and reconnecting it can re-boot the system. I tried this but it did not work.
Has anyone else experienced this?
Post by sich1 on Nov 25, 2022 16:16:24 GMT
i was going to suggest disconnect the battery leads but i can see you have done that. maybe go through the fuse panel and test all the fuses, sounds like may have blown?
ravjeff
Model Spec/Trim: GLX
Engine Capacity: 2.5L
Post by ravjeff on Nov 25, 2022 19:01:39 GMT
How long did you disconnect the main battery as I have been told you have to leave it disconnected for minutes not just seconds. Sorry but I can't remember how many minutes.
Post by unclebob on Nov 25, 2022 19:23:01 GMT
First off welcome to the club 👍🏻 Remembering other members possible problems … fusable link on the red battery terminal . Or windscreen letting water in, and running down to the fuse box on drivers or passengers kick panels .
