Post by nor on Jun 14, 2020 8:43:17 GMT
Hi Guys,
I live in Norway and couple of days ago bought a Rav4 2007 2.2-136 D that runs perfectly with no dash errors but sometimes it feels a bit dull and lazy. So i decided to check it up with OBD2 bluetooth and elm327 app and booom it suddenly shows me 15 codes. I reseted the codes and drove the car a bit and rescaned and got exactly the same codes. Can someone kindly look at this and tell what should i fix and what is not important. As i am student and have very limited budget. thanks in advance
Yes i did google but couldnt find alot of info...
Car Scanner ELM OBD2
DTC report
Selected brand: Toyota
============1==============
P2194
Raw code: 2194
ECU: Climate
Status: Confirmed
OBDII: System too rich at higher load, bank 2
============2==============
P0294
Raw code: 0294
ECU: Climate
Status: Confirmed
OBDII: Injector 12 - circuit low
Toyota: Injection Cylinder 12 Circuit Low
============3==============
B1424
Raw code: 9424
ECU: Climate
Status: Confirmed
Toyota: Solar Sensor Circuit (Driver Side) (Progr.)
============4==============
B1421
Raw code: 9421
ECU: Climate
Status: Confirmed
Toyota: Solar Sensor Circuit (Passenger Side) (Progr., RX3))
============5==============
C1298
Raw code: 5298
ECU: Dashboard
Status: Confirmed
============6==============
C1249
Raw code: 5249
ECU: ABS
Status: Confirmed
Toyota: Brake Light Switch Circuit Malfunction (Cam., MR)
============7==============
C1223
Raw code: 5223
ECU: ABS
Status: Confirmed
Toyota: Malfunction in ABS Control System (RX3)
============8==============
B2799
Raw code: A799
ECU: Engine control unit
Status: Confirmed
Toyota: Immobiliser Fault; Engine Immobiliser System Malfunction
============9==============
P2194
Raw code: 2194
ECU: Climate
Status: Confirmed
============10==============
P0294
Raw code: 0294
ECU: Climate
Status: Confirmed
============11==============
B1424
Raw code: 9424
ECU: Climate
Status: Confirmed
============12==============
B1421
Raw code: 9421
ECU: Climate
Status: Confirmed
============13==============
C1298
Raw code: 5298
ECU: Dashboard
Status: Confirmed
============14==============
C1249
Raw code: 5249
ECU: ABS
Status: Confirmed
============15==============
C1223
Raw code: 5223
ECU: ABS
Status: Confirmed
DTC report
P2194
Raw code: 2194
ECU: Climate
Status: Confirmed
P0294
Raw code: 0294
ECU: Climate
Status: Confirmed
B1424
Raw code: 9424
ECU: Climate
Status: Confirmed
B1421
Raw code: 9421
ECU: Climate
Status: Confirmed
C1298
Raw code: 5298
ECU: Dashboard
Status: Confirmed
C1249
Raw code: 5249
ECU: ABS
Status: Confirmed
C1223
Raw code: 5223
ECU: ABS
Status: Confirmed
B2799
Raw code: A799
Status: Confirmed
P2194
Raw code: 2194
ECU: Climate
Status: Confirmed
P0294
Raw code: 0294
ECU: Climate
Status: Confirmed
B1424
Raw code: 9424
ECU: Climate
Status: Confirmed
B1421
Raw code: 9421
ECU: Climate
Status: Confirmed
C1298
Raw code: 5298
ECU: Dashboard
Status: Confirmed
C1249
Raw code: 5249
ECU: ABS
Status: Confirmed
C1223
Raw code: 5223
ECU: ABS
Status: Confirmed
