Post by Hoovie on Mar 3, 2019 14:07:13 GMT
I fitted the Toyota one to my 4.2 3 Door Auto and it was a super-simple job as Jase describes (I swapped the entire wheel over when I did mine) I did fit a GoldCruise System to my 4.2 5 Door Manual and that was great (and better than the Toyota System but around 10 times the cost!). I did on the Manual 4.2 have to fit a switch to the clutch pedal though as none was fitted (that I could see anyway). Maybe some have switches as standard fitted or the ECU detects when the clutch is depressed somehow (a raise in engine revs or sudden drop in engine load?) I think a lot of vehicles where Cruise is an option are pretty ready for a factory retro-fit? I added OEM Cruise to my VW T5 by changing the stalk set, but did also have to do some wiring addition to the BM ('Body Management') ECU and a wire through the bulkhead to a connection near the battery. Had to enable it in the ECU as well but no extra electronics were needed. The Toyota add-on is a lot easier Any problems with the air-bag when you did the 3-dr, David? Nope. Just disconnected the bag and removed (after leaving for a time), then refitted again once new wheel in place and tested.
Post by jasehutch on Mar 3, 2019 17:12:09 GMT
I simply did the same as Bob and left the airbag connected but slipped it through the steering wheel spokes out of the way.
nrg
Primary Vehicle: Toyota Rav4 NRG
Year: 2002
Model Spec/Trim: NRG
Engine Capacity: 2.0
Post by nrg on May 23, 2019 18:39:01 GMT
Wow
I need this in my life, really that simple? I have a 2002, 3 door manual NRG. Is there any pre checks I can do to make sure it will work before taking the plunge?
Post by unclebob on May 23, 2019 19:51:44 GMT
Sorry to burst your bubble but can’t be done on the pre facelift model , your car has a throttle cable later cars have a fly by wire throttle, it’s the electronics that allow a cruise control to be fitted as a plug and play 👍🏻 Your option is an aftermarket cruise control kit 👍🏻
Post by Hoovie on May 23, 2019 19:56:50 GMT
Sorry to burst your bubble but can’t be done on the pre facelift model , your car has a throttle cable later cars have a fly by wire throttle, it’s the electronics that allow a cruise control to be fitted as a plug and play 👍🏻 Your option is an aftermarket cruise control kit 👍🏻 I still have my Gold Cruise unit that I fitted on my RAV4.2 and available for sale at a very reasonable price (although will be more than the cost of an OEM stalk )
nrg
Year: 2002
Post by nrg on May 23, 2019 21:16:03 GMT
My bubble is burst, thanks tho!
Post by unclebob on May 24, 2019 10:04:59 GMT
My bubble is burst, thanks tho! Cruise control is still a worthwhile addition to any Rav4 if you do a fair bit of motorway driving 👍🏻
