Post by firemac on Apr 26, 2021 12:26:12 GMT
OK what next? £300+ on tyres but still doing it. My thoughts are now auxiliary belt and get all the transmission oil changed. It's like a droning noise. I noticed that it changes slightly when the wheel is turned so that got me thinking about the belt because of the power steering pump. Could be. Do you have the service history? AFAIR the serpentine belt is changed every 60K miles or 6 years. You should be able to tell by having a good look and poke at the belt whether it’s past it’s best. Cannot remember what the trans oils change period is but I do recall that the 4.2 is very fussy about the spec of oil used in the gearbox, diffs and transfer box. The wrong weight of oil will cause problems.
pmb
Primary Vehicle: Rav4
Year: 2002
Model Spec/Trim: VX
Engine Capacity: 2000
Post by pmb on Apr 26, 2021 13:55:48 GMT
Yes firemac. I've had it from new. Back in 2008 was when the belt was changed. We both posted on a thread about the belt on the toc forum. Booked in for tomorrow. Needs doing even it is not that.
Post by bigkev on Apr 26, 2021 16:46:45 GMT
I showed Andy and Don how to do gearbox, rear diff, and tranny box oil on wife’s now gone 3 door. The smell of the tranny box oil filled the street....! Andy got that job. Gears were much smoother changing and whole car seemed to quieten down.....wurff it imho.
Post by davrav on Apr 26, 2021 17:29:15 GMT
When changing the serpentine belt get the tensioner done at the same time as the bearing in the roller does wear. Could be the source of the drone maybe?
Post by shcm on Apr 26, 2021 19:14:11 GMT
The smell of the tranny box oil filled the street....! Andy got that job. You sure that wasn't the smell of cremated pork and pastry product? (I have a elephant's memory and will only let that one go once I've gone completely senile. )
(or maybe I just hadn't had a shower).
