Post by rangers94 on Feb 4, 2021 16:06:49 GMT
I just replaced the spark plugs, pcv valve, air filter and cleaned the throttle body and maf sensor on my 2008 v6 2wd. The next day while driving the check engine light, the vsv light and stability car symbol came on. I am not sure why and what to do.
Thanks for any and all advice
Post by three5 on Feb 4, 2021 17:43:06 GMT
I just replaced the spark plugs, pcv valve, air filter and cleaned the throttle body and maf sensor on my 2008 v6 2wd. The next day while driving the check engine light, the vsv light and stability car symbol came on. I am not sure why and what to do. Thanks for any and all advice Hi Rangers94, Can you give us a little more information about your RAV please? It might also help if you say where you are based as the V6 engine was never an option in the UK where the majority of us are living. That being said, there is a lot of Toyota experience within the group and at the very least we are likely to be able to point you in a sensible direction if we can't solve the problem
