skillmaker
Primary Vehicle: Rav4 4.3
Year: 2009
Engine Capacity: 2.2 D4D
Post by skillmaker on Jan 24, 2021 22:48:15 GMT
Hi, I removed the battery's negative Terminal to remove My android unit to place GPS Antenna in a better place , i finished everything , Put the battery terminal back again and now i have an airbag light on and " Check airbag system" message that won't go , i connected my OBD to scan fault code but there is no fault code shown , how to turn it off ?
Post by unclebob on Jan 24, 2021 22:53:18 GMT
Hi, I removed the battery's negative Terminal to remove My android unit to place GPS Antenna in a better place , i finished everything , Put the battery terminal back again and now i have an airbag light on and " Check airbag system" message that won't go , i connected my OBD to scan fault code but there is no fault code shown , how to turn it off ? If I’m correct the basic OBD2 reader just does engine codes, other dedicated readers are sold for airbag systems ...hopefully someone will back me up on that 👍🏻👍🏻
Post by firemac on Jan 24, 2021 22:57:47 GMT
Hi, I removed the battery's negative Terminal to remove My android unit to place GPS Antenna in a better place , i finished everything , Put the battery terminal back again and now i have an airbag light on and " Check airbag system" message that won't go , i connected my OBD to scan fault code but there is no fault code shown , how to turn it off ? If I’m correct the basic OBD2 reader just does engine codes, other dedicated readers are sold for airbag systems ...hopefully someone will back me up on that 👍🏻👍🏻 I've always understood that airbag and ABS need specialist kit to read the codes, Bob. 👍
Post by shcm on Jan 25, 2021 8:35:06 GMT
Yeah, the vast majority of the cheap OBD readers will only deal with powertrain DTCs (DTC's beginning with "P").
Airbag/Restraints are usually classified under DTCs beginning with "B" (Body).
Check you didn't disturb or just haven't reconnected all airbag/seatbelt/crash sensor connectors, that might have been disconnected, while routing the GPS antenna cable.
