Post by Ravasher on Dec 4, 2020 11:48:21 GMT
Last few days the “clean radar sensor” message is appearing on the dash. No cruise control and pre collision are not working either. I ah e no idea where the sensor is either can someone point me in the right direction please. The car is clean and washed every week so no idea why it’s coming on.
Post by shcm on Dec 4, 2020 11:51:54 GMT
It's directly behind the front badge Ash (or more often than not is).
If there's nothing obscuring the badge, first see if you can check nothing has fallen in between the gap between badge and radar.
EDIT: Snow and ice on the front of the badge can also cause this, if that helps. I know almost nothing about such devices.
Post by clarki on Dec 4, 2020 11:55:10 GMT
Our CX-5 used to do that. No apparent reason. Would go away as quick as it came on though??!!
The Mazda sensor was in the badge in the grille. We often wondered if it came on after using the scoochers (they do the headlights at the same time as the windscreen when the lights are on). But this was just a guess tbh.
