Post by bigkev on Oct 26, 2020 14:44:17 GMT
OK thanks folks Just ordered em from Amazon £4 cheaper than my link above and should be here tomorrow Now are they easy to fit or are these the ones where you need tiny hands to get in? Must wear nitrile gloves, as lotsa sharp metal in the way and helps with any accidental contact with bulb glass which buggers it prematurefully. Passenger side a dawdle......driver’s side......remove wee black popper which secures screenwash filler neck, and bend said neck towards car front oot the way.....improves access if not got a Gynaecology degree. IMPORTANT.......you will note new bulb has a rubber grommet/washer seating ring fing........make sure it comes away with OLD bulb removal, as you will never get new wans seated if old grommet still in shitu......Sean Connery speak. What a neck spert.....!
Post by Paulus17 on Oct 26, 2020 14:46:20 GMT
HERE is the Amazon link if anyone else is thinking of changing.
Post by Paulus17 on Oct 26, 2020 14:47:46 GMT
Thanks for the video Bob looks simples enough, famous last words :yes:
Post by Paulus17 on Oct 26, 2020 14:54:17 GMT
OK thanks folks Just ordered em from Amazon £4 cheaper than my link above and should be here tomorrow Now are they easy to fit or are these the ones where you need tiny hands to get in? Must wear nitrile gloves, as lotsa sharp metal in the way and helps with any accidental contact with bulb glass which buggers it prematurefully. Passenger side a dawdle......driver’s side......remove wee black popper which secures screenwash filler neck, and bend said neck towards car front oot the way.....improves access if not got a Gynaecology degree. IMPORTANT.......you will note new bulb has a rubber grommet/washer seating ring fing........make sure it comes away with OLD bulb removal, as you will never get new wans seated if old grommet still in shitu......Sean Connery speak. What a neck spert.....! Thanks BK :TU: I won't probably attempt em till the weekend so will let you know i gets on :yes:
Post by firemac on Oct 26, 2020 15:25:48 GMT
Never had a problem changing the RAV's bulbs (the sidelight bulbs are another matter entirely!!!! :no:)
The Saab's h/l bulbs are a complete sh1t to change!
Post by unclebob on Oct 26, 2020 15:37:02 GMT
Thanks for the video Bob looks simples enough, famous last words Observations....the plug on the back of the bulb can be tricky to pull off and don’t touch the glass on the new bulbs 👍🏻
Post by Paulus17 on Oct 27, 2020 15:55:40 GMT
Well the bulbs arrived first thing this morning so told Mrs P dinner time when she phoned that her bulbs had come and she said "where we planting those" Anyway they were well packed so will attempt them over the weekend :TU:
Post by three5 on Oct 27, 2020 16:30:29 GMT
Well the bulbs arrived first thing this morning so told Mrs P dinner time when she phoned that her bulbs had come and she said "where we planting those" Anyway they were well packed so will attempt them over the weekend I'll be very interested in your ( and Mrs P's ) opinion when you've got them fitted and tested. I'm lucky in that I've a length, over half a mile, of dead straight, unlit, dead end road locally where I tried out my existing nightbreakers ( the original version ).
Post by unclebob on Oct 27, 2020 19:37:13 GMT
I’ve ordered a set from Amazon too 👍🏻👍🏻
Post by sich1 on Oct 27, 2020 19:58:51 GMT
damn it, now if have ordereed some too
Post by unclebob on Oct 27, 2020 21:16:55 GMT
damn it, now if have ordereed some too Kev’s such an influence and good all round wise monkey 🙏🙏😉
Post by widge on Oct 27, 2020 22:00:44 GMT
Never had a problem changing the RAV's bulbs (the sidelight bulbs are another matter entirely!!!! ) The Saab's h/l bulbs are a complete sh1t to change! It cant be as bad as the Citroen Xsara that I used to own, I liked the car but wasnt happy about the main beam so bought some new bulbs, then spent an hour trying to get my hand into a position to try and remove one of the headlight bulbs, eventually I popped into the dealer where I bought the car, they said you have to remove the headlight unit, and to do that you have to remove the front bumper.
Needles to say I put up with the existing bulbs.
Post by sich1 on Oct 27, 2020 22:57:20 GMT
it will make me polish the lights again to get the best from them....more work!
Post by mikis on Oct 29, 2020 13:45:56 GMT
Hallo
Would this fit to MK III ?
Post by three5 on Oct 29, 2020 13:49:03 GMT
Hallo Would this fit to MK III ? No, the 4.3 had a twin headlight configuration with independent bulbs for the main and dip beams. I expect that you will find the Nightbreaker Lasers are available in the right bulbs for your motor.
