Post by Paulus17 on May 5, 2022 20:27:34 GMT
Lucky he didn’t bring along some of his buddies and build a nest. A wasp RV; that would’ve been interesting! 🤔😂 Too right Jim, i've had a few nests staring in the garage but they haven't come to anything yet.
Post by Paulus17 on May 5, 2022 20:29:24 GMT
Nice one Paul..👍 That's one of the best mods I did to my Rav as it makes such a difference. Cheers Jase, it is well worth doing, there have been a couple of times we could've done with the opening wider already :yes:
Post by Paulus17 on May 5, 2022 20:31:29 GMT
Don't forget to put a strip of red refective tape down the leading edge of the door to keep yourself legal. With the door opening to 90-degrees, the offside taillight/reflector will no longer be visible to approaching traffic when the door is open. Does it have to be tape Jim as i was thinking of a couple of plastic reflectors??
Post by jasehutch on May 5, 2022 21:10:34 GMT
Don't forget to put a strip of red refective tape down the leading edge of the door to keep yourself legal. With the door opening to 90-degrees, the offside taillight/reflector will no longer be visible to approaching traffic when the door is open. Does it have to be tape Jim as i was thinking of a couple of plastic reflectors?? That's what I used Paul..👍
Post by firemac on May 5, 2022 21:31:22 GMT
Does it have to be tape Jim as i was thinking of a couple of plastic reflectors?? That's what I used Paul..👍 Plastic reflectors are fine, Paul. I only mentioned tape because that’s what I used.👍
Post by unclebob on May 6, 2022 11:52:07 GMT
Job well done Paul, bit tricky drilling the pin but you’ve done it now 👍🏻 I added a few washers as I was knocking the pin in so it was not loose 👍🏻
Post by Paulus17 on May 9, 2022 10:42:47 GMT
Cheers Bob :TU: That's all the jobs done now i had on the list but i/we have now noticed summat else regarding the paintwork on the drivers door and the bonnet, it seems to be flat now? I have checked on the photos when we first had the car and both panels looked good, you can see a clear reflection but now for some reason they do look flat, so what could've caused this??
Post by Paulus17 on Nov 28, 2022 19:52:34 GMT
Just some updated piccys of our Rav after it's recent respray on the door bonnet and rear quarter panel. Also noticed the gap on the rock bars between the sill. Should that be there or should the bar be a closer fit to the sill. As i remember there was no adjustment on the bars when i fitted them.
Post by Paulus17 on Dec 6, 2022 13:00:26 GMT
Well the two new genuine headlights have arrived safe and sound, another big thank you to Kingo, cheers John :TU: However is this time of year a good time to be fitting them with the plastic lugs and clips been cold and more brittle for breaking or should it be ok?
Post by jasehutch on Dec 6, 2022 13:09:43 GMT
Ace Paul , it's going to look fab..👍
Post by three5 on Dec 6, 2022 14:17:27 GMT
Well the two new genuine headlights have arrived safe and sound, another big thank you to Kingo, cheers John However is this time of year a good time to be fitting them with the plastic lugs and clips been cold and more brittle for breaking or should it be ok? the low temperature is a very good point. A bit of local "warm" from a hair dryer or hot air gun wouldn't hurt and it's good for the fingers as well!
Post by Paulus17 on Dec 6, 2022 15:16:45 GMT
Ace Paul , it's going to look fab..👍 Thanks Jase :TU: We're hoping it will improve the lighting Jase but time will tell :yes:
Post by Paulus17 on Dec 6, 2022 15:20:10 GMT
Thanks Chris, i was thinking of using the hairdryer but looks like we are in for a cold snap now so will see if the temps improve soon :TU:
Post by davrav on Dec 6, 2022 15:51:47 GMT
Shiny, shiny Paul. I won't ask what you paid for them but I have a brand new pair of 4.3 headlights still in their Toyota boxes somewhere in my garage that I picked up for £15 each way back when. I suspect that, had I not had the originals coated with Ventureshield, those spare ones would have been on the car some time ago.
Post by unclebob on Dec 6, 2022 16:07:13 GMT
Crank the heater up in your garage Paul….. and you’ll be fine 👍🏻👍🏻
