vxben
Junior Member
Can't find how to start new thread
Primary Vehicle: 2.2 diesel
Year: 2012
Post by vxben on May 9, 2020 21:17:44 GMT
Hi all recently bought a 2012 RAV4 2.2 diesel 1 owner full Toyota history 87000 miles ,really happy but just think there is a lot of turbo whistle compared to my old 320d is this normal on the rav or is my turbo on the way out ?does the rav suffer with turbos?I've changed oil air filter just done rear diff oil and breather,but turbo whistle is a bit unnerving had a quick look under bonnet all pipe work seems ok it's always whistled, I know all turbos do some louder than others but it's like driving a skyline!its definitely not a siren sound like when a turbo has blown hasn't lost any performance just seems excessive I've read somewhere a failing altanator can make a similar sound?used a good c3 5w/30 Castrol oil for change any thoughts?
Post by davrav on May 9, 2020 21:49:26 GMT
Hi and  . Are you certain it is the turbo? Serpentine belt tensioner can also whistle a bit at high mileage.
Post by firemac on May 9, 2020 22:34:00 GMT
If you are not sure where the whistle is coming from, you could try the screwdriver test. Get a long screwdriver or a tommy bar, hold one end to your ear and place the other end against the alternator or whichever ancillary bit of kit that you want to test. The bar will act like a stethoscope and amplify any noises being made by the unit. Just make sure that there are no bits of clothing dangling near the serpentine belt, etc!😣
Post by widge on May 10, 2020 7:36:16 GMT
Hi and  . Are you certain it is the turbo? Serpentine belt tensioner can also whistle a bit at high mileage. surly a turbo would only whistle when it kicks in over a certain rpm, but a belt would whistle all the time, although maybe quieter at low revs.
vxben
Junior Member
Year: 2012
Post by vxben on May 10, 2020 9:49:37 GMT
Anyone else had a whistling turbo before 100.000 MLS how do these VB turbos last wondering if poor oil feed would using a c3 5w/30 over a 0w oil reduce oil feed?
vxben
Junior Member
Year: 2012
Post by vxben on May 10, 2020 9:51:48 GMT
Also just added a bottle of forte turbo cleaner to a tank to see if this helps
Post by davrav on May 10, 2020 10:35:43 GMT
Just a matter of housekeeping but, would you please fill in your profile with some details so folks who stop by know what model we are talking about without the need to go to your first post to find out.
