mikegml
Primary Vehicle: RAV4 VVTi 2.0 3 door
Year: 2005
Post by mikegml on Jan 11, 2020 16:19:56 GMT
Post by firemac on Jan 11, 2020 16:43:50 GMT
It looks like the cover for the VIN number that lives on the chassis rail under the front of the driver's seat. It should just clip back into place.
Post by davrav on Jan 11, 2020 17:50:37 GMT
+1 for the above :TU:
Post by unclebob on Jan 11, 2020 18:36:35 GMT
Agree vin cover 👍🏻👍🏻
mikegml
Year: 2005
Post by mikegml on Jan 11, 2020 20:31:24 GMT
mikegml
Year: 2005
Post by mikegml on Jan 11, 2020 20:50:23 GMT
While you're here............I've got two plastic clips fixed to the floor where the back edge of the drivers carpet would be if you had one, which I have (cheapo but good). What are they? Looks like maybe a fancy Toyota carpet would clip into them to keep them in place or something.
Correct or not?
Just thought of another one. In the rear left hand side compartment, the one where you unclip and remove the side panel, there is a strap that obviously is made to hold something down. What?
Post by firemac on Jan 11, 2020 21:02:23 GMT
The clips anchor Toyota's OEM mat in place.
AFAIK, the strap in the rear cubby allows you to keep anything in there from sliding about, e.g. first aid kit, etc. I keep a bottle of spray detailer and some microfiber cloths in there to deal with bird crap on the paintwork, which happens way too often.
mikegml
Year: 2005
Post by mikegml on Jan 11, 2020 21:07:00 GMT
Cheers. Yeah I thought that's what the clips were for. Dunno why there isn't a strap in the right side then, or maybe there is? I've chucked the jack in that one, fits perfect with the other tyre bits.
Post by firemac on Jan 11, 2020 21:19:09 GMT
Cheers. Yeah I thought that's what the clips were for. Dunno why there isn't a strap in the right side then, or maybe there is? I've chucked the jack in that one, fits perfect with the other tyre bits. I'm pretty sure there's a strap in the offside cubby as well. The jack is mounted under the driver's seat in the 4.2.
Post by bigkev on Jan 11, 2020 22:09:40 GMT
The jack has an apperture it fits in underneath the driver’s seat, directly behind where that plastic cover came off.
mikegml
Year: 2005
Post by mikegml on Jan 11, 2020 22:55:05 GMT
Cheers. I saw the jack in it's correct position, didn't really like it there tho' I've no big objection to it, so moved to the RHS rear cubby hole where it fits perfect with the bag containing the brace which like most braces is wank, but I also have my other bigger brace, and it all fits in there just nice.
