Post by Paulus17 on Nov 26, 2019 12:53:26 GMT
I found the back door check strap from our 2004 5 door Rav today. Would this be the same fitting on our 2002 3 door? It's not the one that opens fully from later models.
Post by bigkev on Nov 27, 2019 17:14:17 GMT
Unless it’s one that opens fully, Paul, it’s actually a very strangely shaped frisbee. Why you ask......yours broken or rough in operationment....?
Post by firemac on Nov 27, 2019 17:23:29 GMT
It's off a 4.2 so I would guess that it will probably fit yours. AFAIK the rear door fittings were the same on 4.2 and the later 4.2.5.In any event I believe that all UK cars had rear doors that didn't open to 90 degrees in order to not obscure the tail lights. You can fit a US-spec door strap that allows full opening but if you do then you are breaching UK C&U regs and maybe your insurers might get a bit miffed if a claim was made as a result of the lights being obscured.
I'm not certain on the latter point but, given that some insurance companies are crazy enough to disallow things like winter tyres, for example, I wouldn't be one bit surprised.
Post by Paulus17 on Nov 28, 2019 8:51:57 GMT
Unless it’s one that opens fully, Paul, it’s actually a very strangely shaped frisbee. Why you ask......yours broken or rough in operationment....? No Kev this is the one i took off the Blue Rav to replace it with a fully opening one, think I had it off Don, and think it was still working ok, but the one on the Black Rav isn't, well it is but not a very strong hold so will have look over the weekend. Just wanted to know before I strip it all off?
Post by Paulus17 on Nov 28, 2019 8:54:56 GMT
It's off a 4.2 so I would guess that it will probably fit yours. AFAIK the rear door fittings were the same on 4.2 and the later 4.2.5.In any event I believe that all UK cars had rear doors that didn't open to 90 degrees in order to not obscure the tail lights. You can fit a US-spec door strap that allows full opening but if you do then you are breaching UK C&U regs and maybe your insurers might get a bit miffed if a claim was made as a result of the lights being obscured. I'm not certain on the latter point but, given that some insurance companies are crazy enough to disallow things like winter tyres, for example, I wouldn't be one bit surprised. Well that's what i'd have thought Jim but looking on ebay there are all sorts of different ones, but will have a look over the weekend. It is the original one off the Blue Rav so not fully opening but hope the hold is better when open :TU:
Post by bigkev on Nov 28, 2019 11:02:25 GMT
Sense that makes Paul.....just paid £50.00 to replace wife’s on her automatic 2006.......CANNOT see the point of replacing with that one that only allows partial openink.
Post by Paulus17 on Nov 28, 2019 13:38:05 GMT
Sense that makes Paul.....just paid £50.00 to replace wife’s on her automatic 2006.......CANNOT see the point of replacing with that one that only allows partial openink. Not really fussed Kev about the rear door opening fully now, just want it to stay open without a bit of wind closing it when parked on a hill Where did you get yours from?
Post by bigkev on Nov 28, 2019 17:55:20 GMT
Ebay Paul.....if not fussed, keep yer cash, but it would drive me bonkerseez.
Post by phaeton on Nov 28, 2019 18:11:52 GMT
I put a long one on so the door fully opens, I also put an LED round light which is also a reflector on the outside edge of the door, it comes on via the normal door switch. Although I do think it's unnecessary as there are loads of vans that obscure the lights when they are open. I've heard the reason before & wonder if it's just an urban myth.
Post by Paulus17 on Nov 29, 2019 14:22:56 GMT
I'm only wanting to change it as the one on isn't that good so am hoping the one off the Blue Rav will be better :yes: or are all the ones that open to 60 degrees no good and don't stay open??
Post by bigkev on Nov 29, 2019 16:46:18 GMT
There is a very obvious holding detent on opening the 90 degree wan fully, Paul, and quite honestly, the wind currently being caused by my wee malignant bowel tumour could easily shut one of those doors from 60 degrees......lol.......removal FRIDAY THE 13th FFS.......CANNAE MAKE THIS UP.......CAUGHT VERY EARLY AND SO MINISCULE EVEN THE CT SCAN COULDNAE FIND IT......FOUND BY UP PERISCOPE......URRAWISE CT SHOWS ABBALOOTLY NO SPREAD THEREOF, SO BULLET DODGED THERE MINS. Lassie who did the Colonoscopy had NO clue what ah meant when ah said ma bum was like the map on Bonanza after she finished.....! Lol.....
WHAT.....OFF SUBJECT......WHO ME.......?
Post by Paulus17 on Nov 29, 2019 19:58:43 GMT
There is a very obvious holding detent on opening the 90 degree wan fully, Paul, and quite honestly, the wind currently being caused by my wee malignant bowel tumour could easily shut one of those doors from 60 degrees......lol.......removal FRIDAY THE 13th FFS.......CANNAE MAKE THIS UP.......CAUGHT VERY EARLY AND SO MINISCULE EVEN THE CT SCAN COULDNAE FIND IT......FOUND BY UP PERISCOPE......URRAWISE CT SHOWS ABBALOOTLY NO SPREAD THEREOF, SO BULLET DODGED THERE MINS. Lassie who did the Colonoscopy had NO clue what ah meant when ah said ma bum was like the map on Bonanza after she finished.....! Lol..... WHAT.....OFF SUBJECT......WHO ME.......? Glad to hear all is ok BK :TU:
Post by davrav on Nov 29, 2019 20:03:52 GMT
There is a very obvious holding detent on opening the 90 degree wan fully, Paul, and quite honestly, the wind currently being caused by my wee malignant bowel tumour could easily shut one of those doors from 60 degrees......lol.......removal FRIDAY THE 13th FFS.......CANNAE MAKE THIS UP.......CAUGHT VERY EARLY AND SO MINISCULE EVEN THE CT SCAN COULDNAE FIND IT......FOUND BY UP PERISCOPE......URRAWISE CT SHOWS ABBALOOTLY NO SPREAD THEREOF, SO BULLET DODGED THERE MINS. Lassie who did the Colonoscopy had NO clue what ah meant when ah said ma bum was like the map on Bonanza after she finished.....! Lol..... WHAT.....OFF SUBJECT......WHO ME.......? All sounds pretty much 'back door' related to me........... Glad it has been diagnosed early Kev :TU:
Post by Mb2t on Nov 29, 2019 20:28:13 GMT
There is a very obvious holding detent on opening the 90 degree wan fully, Paul, and quite honestly, the wind currently being caused by my wee malignant bowel tumour could easily shut one of those doors from 60 degrees......lol.......removal FRIDAY THE 13th FFS.......CANNAE MAKE THIS UP.......CAUGHT VERY EARLY AND SO MINISCULE EVEN THE CT SCAN COULDNAE FIND IT......FOUND BY UP PERISCOPE......URRAWISE CT SHOWS ABBALOOTLY NO SPREAD THEREOF, SO BULLET DODGED THERE MINS. Lassie who did the Colonoscopy had NO clue what ah meant when ah said ma bum was like the map on Bonanza after she finished.....! Lol..... WHAT.....OFF SUBJECT......WHO ME.......? Good luck with the op! Good it was cought early!
Post by jasehutch on Nov 29, 2019 20:33:57 GMT
All the very very best Kev.. :TU:
