Post by 152bobby on Feb 9, 2018 15:02:00 GMT
Hi,
My driver's door lock has stopped working, all other doors work with either the remote or the keyless entry.
I know where both the fuse boxes are, but can someone tell me which fuse(s) to check.
Thanks
Bobby
Post by Hoovie on Feb 9, 2018 16:40:37 GMT
I don't know if the following is correct or not but this is what I would in lieu of better info .... Lock the doors while holding the handle on the passenger door and see what I can feel. Then repeat with drivers door and see if if similar. Also listen and see if solenoids are active on the door. I am thinking it may be more mechanical than electrical problem and something has popped out of a fitting maybe. Door locks with the key directly?
Post by 152bobby on Feb 9, 2018 17:20:06 GMT
It's ok now David, I was dicking about with something which I shouldn't have, all back to normal...thanks for the quick reply though 👍
Post by phaeton on Feb 9, 2018 17:55:23 GMT
It's ok now David, I was dicking about with something which I shouldn't have, all back to normal...thanks for the quick reply though 👍 You can't leave it at that you have to say what you were doing
Post by 152bobby on Feb 9, 2018 18:18:44 GMT
Ok....I was trying to fit the Auto Folding Mirror kit I got from China weeks ago.
I got it working, but it cocked up the central locking....I've ripped it out and chucked it over the garden fence !!!
I'm crap at auto electrics.
Post by phaeton on Feb 10, 2018 11:10:20 GMT
Ok....I was trying to fit the Auto Folding Mirror kit I got from China weeks ago. Have you seen the Belgium/Dutch/Maybe ones? Not particularly cheap £60 I seem to remember but tried & tested with full support if you need to ask questions
Post by 152bobby on Feb 10, 2018 11:29:09 GMT
Do you have a link to one ?
Post by phaeton on Feb 10, 2018 11:37:54 GMT
Post by 152bobby on Feb 10, 2018 11:40:57 GMT
Thanks, I'll check that out.
Post by 152bobby on Feb 10, 2018 16:45:54 GMT
Ok, following on from my car electrics, I have noticed that the drivers door window does not work !! All other windows work.
Has this got a fuse I can check ?.....or something !!
Post by Hoovie on Feb 10, 2018 17:21:58 GMT
disturbed connections when fitting/removing Mirror kit?
Post by 152bobby on Feb 10, 2018 17:30:20 GMT
Yes, I checked that. But will check again, as it was a wee bit cold when I was doing it and I was pis*** off a bit !!!
The supplied plug in adapters plugged into the rear of the mirror controls in the center console panel, so no where near the door.
But I did tap into some wires in the driver's footwell, so that's where I'll be looking.
Post by 152bobby on Feb 10, 2018 22:56:37 GMT
Post by 152bobby on Feb 11, 2018 14:23:02 GMT
Do the Ravs (like Lexus) have some sort of reset feature for the electrical windows ?
I still cant find out why my driver's door window isn't working !!
