Fault Codes Fuel Circuit
PostPosted by Snow_Drift » Fri Sep 15, 2017 9:54 pm
I am hoping that someone can help. My mother has a 2004 XT4 2.0 Diesel Rav4 that has done 180,000 miles. The car has for many years had an intermittent power loss fault when overtaking at highway speeds.
Recently the problem became more regular and on a long journey the other day the amber engine warning light came on and the car went into limp mode. The car still starts fine and drives but there is hardly any power. The car also seems to surge forward very slightly as you are driving along as if it is trying to clear a fuel blockage.
The vehicle recovery service came out and read the fault codes, which were as follows:
P0627, FUEL PUMP A CONTROL CIRCUIT / OPEN
P0488, EGR THROTTLE POSITION CONTROL RANGE/PERFORMANCE
I replaced the fuel filter today as it is unknown when that was last done. However, that did not solve the problem.
Can anyone tell me what these codes mean and whether I can try and pinpoint the source of the fault. Or at least tell me what I can discount as not being part of the problem e.g. injectors, high pressure fuel pump, SCV valves etc.
Snow_Drift
Newbie
Newbie
Re: Fault Codes Fuel Circuit
PostPosted by ROGER_37 » Fri Sep 15, 2017 10:46 pm
:welcome Snow_Drift :s_howdy
ROGER_37
Club Supporter
Club Supporter
Real Name: MARTIN
Trim Level: XT-R
Fuel Type: 2.2 DIESEL
Country: IRELAND
PostPosted by anchorman » Sun Sep 17, 2017 6:08 am
Snow_Drift wrote:I am hoping that someone can help. My mother has a 2004 XT4 2.0 Diesel Rav4 that has done 180,000 miles. The car has for many years had an intermittent power loss fault when overtaking at highway speeds.
Hello. P0627 on a RAV is linked to the suction control valves. You can sometimes recover them by cleaning them in mild solvent but otherwise, PF Jones do them and sometimes there are bargains to be found on eBay but stick with genuine Toyota or genuine Denso. The moral of the story, stay away from supermarket diesel.
© 2017 RAV4driversclub.com
And another thing......
anchorman
Real Name: Don
Year: 2015
Trim Level: Sportnav
Fuel Type: Euro VI diesel
PostPosted by jase hutch » Sun Sep 17, 2017 8:59 am
Welcome to the club Snow_Drift..... :s_thumbsup
jase hutch
Club Supporter
Club Supporter
Primary Vehicle: 4.2. 3dr
Year: 2004
Trim Level: XT3
Other Vehicle: Toyota IQ
Trim: Auto
Country: U.K.
PostPosted by Snow_Drift » Tue Sep 19, 2017 3:27 pm
Thanks for the welcomes.
I did a bit of reading around on here and google after using the search terms ‘P0627’ and ‘SCV valves’. I saw some of your comments Anchorman on an older post explaining about removing them and cleaning them and also about the supermarket fuel.
I therefore changed the fuel filter, took the valves out tried to clean them as thoroughly as I could using Carb & EGR cleaner, clean diesel, compressed air, and using a small 12v battery to operate the valves out of the car in cleaning solution.
The car was back to normal and pulled fine up to 2500rpm at which point it hit a major flat spot and had no power. The engine amber warning light also went out. The following day the car went back into limp mode and then eventually the amber light was back.
I would imagine that because the car got 50% better after cleaning the valves that this confirms it is definitely the SCV valves? They have actually failed once or twice before but were replaced at the Toyota dealer when the car was much younger and worth more.
I just wanted to try and make sure (as much as possible) that it is the SCV valves before buying them because I don’t want to waste £150 on the valves, find no difference and have to scrap/sell for parts straight after.
Do you know if the gaskets are usually supplied with the valves or is this something that I have to go to a Toyota dealer to get?
Snow_Drift
Newbie
Newbie
PostPosted by anchorman » Tue Sep 19, 2017 4:26 pm
Snow_Drift wrote:Thanks for the welcomes.
Well I can’t guarantee it but usually when that P0627 code comes up, new SCVs fix it. I would give PF Jones a call about the valves and they will tell you what is in the box. I am aware that cleaning them doesn’t always work but its always worth a try.
anchorman
Real Name: Don
Year: 2015
PostPosted by Snow_Drift » Tue Sep 26, 2017 2:26 pm
Thanks. I ordered the valves from PF Jones. I just wanted to check if anyone knows the torque setting for the four small retaining bolts for the valves. Is 10 Nm about right?
Snow_Drift
Newbie
Newbie
PostPosted by sich1 » Tue Sep 26, 2017 5:33 pm
:welcome
i changed my valves about 2 months ago,i used the same amount of pressure when doing them up as i had to apply to remove them :D get a decent 5mm allen key and clean out the heads of the bolts too,make sure it is a good fit.
no gaskets needed as they are a metal to metal fit. good luck :s_thumbsup
sich1
'750 Club' Member
'750 Club' Member
Primary Vehicle: 4.2 D4D
Year: 2004
Trim Level: xt3
Fuel Type: diesel
Other Vehicle: vw polo tsi
Year: 2015
PostPosted by anchorman » Thu Sep 28, 2017 7:34 am
sich1 wrote::welcome
Good advice here, they don't hold the wheels on so just nip them up evenly. They seal on rubber O rings.
anchorman
Real Name: Don
Year: 2015
