Odd Rattle??!!
Odd Rattle??!!
PostPosted by clarki » Mon Aug 21, 2017 8:34 pm
My Rav seems to have developed a rattle at around 2000 rpm in each gear. Seems to be coming from underneath on the drivers side.
Can drive through it and the car is running fine. Just a bit of a niggle tbh. Someone suggested exhaust heat shield?? Any ideas folks? Got to do an oil change this weekend, so will have a closer look then.
clarki
Primary Vehicle: Rav4
Year: 2009
Trim Level: XT-R
Fuel Type: D-4D
Other Vehicle: SLK
Fuel Type: Lots
Country: UK
Re: Odd Rattle??!!
PostPosted by Davrav » Mon Aug 21, 2017 11:27 pm
Heat shield a likely contender - they have a tendency to rot away around the fixing studs. If that is the case with yours Clarki, then couple of penny washers may well do the trick. Be careful as the nuts tend to rust onto the studs and it is really easy to break off the studs. From memory I cleaned up the threads on mine with a fine wire brush and some penetrating fluid and piggy backed new nuts over the old ones.
RAV4 Drivers Club - For all things RAV4 and much, much more!
Davrav
Real Name: David
Primary Vehicle: RAV4 4.3
Year: 2008
Trim Level: XTR+
Other Vehicle: Mitsubishi ASX
Year: 2017
Trim: Auto
Re: Odd Rattle??!!
PostPosted by uncle_p » Tue Aug 22, 2017 6:27 pm
When the heat shield on my old 4.2 rotted away around the bolt holds I couldnt get it off intact. In the end I just manhandled it off and threw it away. It ran for a couple of years after that without any ill effect.
uncle_p
'250 Club' Member
'250 Club' Member
Real Name: Bill
Primary Vehicle: 4.4
Year: 2013
Trim Level: Invincible
Fuel Type: 2.2 Diseasal
Country: Uk
Re: Odd Rattle??!!
PostPosted by NickB75 » Tue Aug 22, 2017 9:34 pm
I know loads of people who run high performance turbocharged cars with shields removed,no issues.
NickB75
Club Supporter
Club Supporter
Real Name: Nick
Year: 2010
Trim Level: X-TR
Fuel Type: Heavy Oil
Country: United Kingdom
