Post by unclebob on Jun 15, 2023 11:20:37 GMT
My OCD is well under control, so can live with the crack …although it just looks like a scratch up close 👍🏻
Post by philip42h on Jun 15, 2023 11:24:15 GMT
It's a very neat repair ... :TU:
'fill', respray and polish out?
Post by jasehutch on Jun 27, 2023 18:14:59 GMT
Bob , I meant to ask , when you fitted the tweeters to the Rav doors , was the wiring already there ?
Post by unclebob on Jun 27, 2023 19:22:04 GMT
Bob , I meant to ask , when you fitted the tweeters to the Rav doors , was the wiring already there ? No had to bring the wires up from the lower door speaker….it’s not a fancy component set up with a crossover. Simple.. yet it sounds so much better for the outlay 😎
Post by unclebob on Jul 17, 2023 11:35:10 GMT
Took rear arch off to refit the rubber infill trim, used a trade sealer and will leave it 24hrs to go off.
Post by Paulus17 on Jul 31, 2023 8:56:45 GMT
Hows it going Bob, all done now? My brother did ours when we had all the back off to the reverse beep beeps anmd have stayed put thankfully :TU:
Post by unclebob on Jul 31, 2023 13:14:07 GMT
Hows it going Bob, all done now? My brother did ours when we had all the back off to the reverse beep beeps anmd have stayed put thankfully Few days later the arch lifted away at the back end, seems the blue clips are toast…have ordered full set of clip and will do it again soon 👍🏻
Post by Paulus17 on Jul 31, 2023 14:09:39 GMT
Hows it going Bob, all done now? My brother did ours when we had all the back off to the reverse beep beeps anmd have stayed put thankfully Few days later the arch lifted away at the back end, seems the blue clips are toast…have ordered full set of clip and will do it again soon 👍🏻 Can't remember how my brother did ours Bob, not sure if he already had a load of clips and replaced the broken ones. I know the one side was held on with a load of black mastic type stuff that we got off.
Post by unclebob on Jul 31, 2023 19:26:48 GMT
I also bought a roll of 5mm double sided tape..foam backed like the original . Will have a go at it, if I get two dry days on the trot down this way !
