fireballbob
Model Spec/Trim: 4.3.5
Post by fireballbob on Oct 16, 2019 16:32:48 GMT
I started to notice a smell of damp in the car over the last week. thought the matts may have got wet during all the bad weather we've had recently.i soon ruled that out, and started to have a look around. discovered that the plastic tray in the boot had some water in the jack storage compartment. i removed the plastic tray and found around an inch of water in the metal tub. i removed the two rubber bungs , emptied and dried the area.Next is how does water get in there in the first place. I've checked behind the rear light fittings all bone dry . I've checked the rear door seal all appears good , the top left is slightly loose so i smeared some grease on. as its lipped can't see how water would get through. never had a problem for the last 7 or so years so started to think what's changed. 1. my neighbour got out of his car while it was still in auto and did some very minor damage to my rear bumper. being a reasonable guy he paid for Mr T to supply and fit a new one. 2. earlier this year i had a witter tow bar fitted to carry bikes. its a mystery to me. any ideas?
Post by davrav on Oct 16, 2019 16:53:20 GMT
Rear door tight when shut?
fireballbob
Post by fireballbob on Oct 16, 2019 18:00:36 GMT
Rear door tight when shut? Thanks. just checked, seems very firm.
Post by davrav on Oct 16, 2019 20:59:36 GMT
Been carrying any liquids recently?
fireballbob
Post by fireballbob on Oct 17, 2019 8:26:16 GMT
only shopping. and i'd soon notice any booze missing
Post by phaeton on Oct 17, 2019 10:16:53 GMT
Dry out, get small grandchild close door sealing child on-board, get out hose pipe & douse, only stop when child starts to cry they are getting wet.
Post by clarki on Oct 17, 2019 10:52:24 GMT
My mums mk3 Yaris (horrible car) had a leaky boot. Turned out one of the rear light lenses didn't have its rubber seal fitted. Seal was fitted, boot stopped leaking.
fireballbob
Post by fireballbob on Oct 17, 2019 11:37:16 GMT
no grandchildren. could try with my 6 foot son but he may end up putting me in there!
fireballbob
Post by fireballbob on Oct 17, 2019 11:42:42 GMT
My mums mk3 Yaris (horrible car) had a leaky boot. Turned out one of the rear light lenses didn't have its rubber seal fitted. Seal was fitted, boot stopped leaking. checked what i could see, which was,nt much, with a torch seems dry.
Post by Mb2t on Oct 17, 2019 12:35:30 GMT
My mums mk3 Yaris (horrible car) had a leaky boot. Turned out one of the rear light lenses didn't have its rubber seal fitted. Seal was fitted, boot stopped leaking. checked what i could see, which was,nt much, with a torch seems dry. On the Corolla i had similar issue - it was the rear right light cluster - the seal got old (consider it was then 18years old...)- put new rubber (neoprene tape) and problem was solved.
Post by davrav on Oct 17, 2019 16:16:31 GMT
Wonder if one or both rear lights were removed when rear bumper was replaced (can't think why necessary but.....)and then not re-fitted correctly?
Post by phaeton on Oct 18, 2019 11:44:23 GMT
no grandchildren. could try with my 6 foot son but he may end up putting me in there! That you know of
fireballbob
Post by fireballbob on Oct 18, 2019 11:55:52 GMT
Wonder if one or both rear lights were removed when rear bumper was replaced (can't think why necessary but.....)and then not re-fitted correctly? i will check with Mr T.
fireballbob
Post by fireballbob on Oct 18, 2019 11:57:31 GMT
haha
fireballbob
Post by fireballbob on Oct 18, 2019 12:11:29 GMT
also have a problem with the electrics with my new tow bar. rang towbar company who have arranged to get it sorted. while i was on the phone i asked how they get access to the wiring. you've guessed it, they remove a rear light cluster!!!. im not impressed. they are going to fix it and i wonder if i should give them a new seal?. or can they be reseated or ??. thanks all for pointing me to rear light cluster.
